Old 13th April 2007, 08:16 AM   #1
Lovan is offline Lovan  Sweden
Lovan's Avatar
Send a message via ICQ to Lovan
Default Output resistor in feedbackloop?
I'm making a general headphone-amp using an opamp and stumbled upon the question if the outputresistor should be in the feedbackloop or outside?
/Niclas
Old 13th April 2007, 09:02 AM   #2
AndrewT is online now AndrewT  Scotland
are you referring to the resistor that sets the output impedance and also gives a resistive load to improve stability and a bit of short circuit/muting protection?
Then it goes outside the loop.
If the resistor is inside the loop then NFB tries to reduce it's effect to near zero.
regards Andrew T.
Old 13th April 2007, 10:46 AM   #3
Lovan's Avatar
Hi Andrew
Exactly my thoughts. Thanks for confirming them!
/Niclas
Old 14th April 2007, 05:21 PM   #4
jcx is offline jcx  United States
you can have it both ways
resistive feeback around the series R reduces ouput impedance at low frequencies
C feedback from the chip output can dominate the feedback at high frequencies where the series R isolates the op amp output from destabilizing C load
more complicated with typical power chip amps that are not unity gain stable but still possible
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
5% output resistor xplod1236 Parts 4 31st July 2004 12:29 AM
Gainclone output resistor aeronaut Chip Amps 17 7th May 2004 09:26 PM
GC 0,22R output resistor 2Bak Chip Amps 15 3rd March 2004 07:19 AM
Page generated in 0.09908 seconds (60.71% PHP - 39.29% MySQL) with 10 queries
