| Chip Amps Amplifiers based on integrated circuits |
It may sounds crazy,but have anyone try it before???
#2 |
I have actually built a few useing 1% and even a very succesfull design useing 5% tolerance carbon comps in a BPA200
#3 |
:Hands raised:
Audiosector LM4780 kits, connected as BPA, using the resistors that came with the kit. I don't think those are matched... |
#4 |
Resistors are cheap. buy 20 or so and and measure them. pick the closest ones.
#5 |
Exactly true.
I done that methode for my LM4780 GainClone and have only 0.2mV offsets in each channel while inputz shorted (but I have very balanced SMPS for PSU).. I bought 40 pcs for 20K feedback and input load and 40 pcs for 1K and matched them with my 4000 count multimeter. I also matched the capacitors with the same technic. It takes only 10 minutes! Thats all. No need for %0.1s..
Best regards, Ozgur |
#6 |
Most 1% are actually within about 0.3%. Should be good enough.
Listen to the music through the stereo, not the stereo through the music. |
#7 |
Actually in the bridge circuits I've seen one side (the non-inverting side)
has 1k and 20.5k resistors and the other side (inverting side) has 21.5k resistors. I'm not sure why the difference or how critical this is. I suppose given enough resistors and an acurate ohmmeter one could hand pick 1k and 22k 5% resistors to work, or parallel high value resistors with the 22k to get the desired values. |
#8 |
In the bridge ciruits I've seen one side (non invertng) uses 1k and 20.5k resisters and the other (inverting) uses 1k and 21.5k resisters.
I'm not sure why and how critical this is. I suppose one could hand pick from 22k 5% resistors with a good ohmmeter or parallel high value resistors with the 22k to trim to the desired value. |
#9 | |
Because one side is inverting and one is non-inverting. The formula for calculating the gain is slightly different for the different types. See http://en.wikipedia.org/wiki/Operati...r_applications for the difference. If you plug the numbers in, you'll find they end up with the same gain using different resistors.
#10 |
You might consider making your own Wheatstone Bridge ( http://en.wikipedia.org/wiki/Wheatstone_bridge ) ... I have one I picked up from a trade school inventory close out made in a nice wooden box = works great and can measure and match resistors to 0.01% with a 9 Volt battery as source and an el cheapo voltmeter.
Over compression is a problem with modern CD recordings |
| 5 Watt Resistors on Aleph 4 and Holco Resistors | nicharis | Pass Labs | 16 | 8th February 2012 07:50 AM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 11:47 AM |
| Matched tubes or not matched | hilbert_mostert | Tubes / Valves | 29 | 27th March 2009 10:13 PM |
| 400+ 5% carbon comp resistors 1/8-2W 1% or better matched pairs available | sdedalus | Swap Meet | 3 | 22nd June 2006 04:31 AM |
| Inductive resistors for source resistors | bbakota2000 | Pass Labs | 12 | 25th March 2005 11:33 AM |
| Page generated in 0.10913 seconds (75.46% PHP - 24.54% MySQL) with 10 queries |
