| Chip Amps Amplifiers based on integrated circuits |
I would like to build de Tube Gainclone but i have some questions
I have 2 transformers of 24V - 160vA - 3,3 A , and 2 more transformers of 15V - 160vA - 5A for the chipamp (withouth bridgerectifiers) The first seems the most usual in chipamps but i would like to reserve it for another project The question have relation with the transformers Itīs possible to make the chipamp with the 15V transformer and the same valve transformer of the original project (25V Low current)? In the original project itīs the same voltage but i never had worked with valves and i donīt know if there is a necessary voltage relation or not Help Regards Miguel |
#2 |
#3 |
Hummmm......
Perhaps i dont understand what do you mean ( also i have problems with the English) I ask if it is possible to run with the 35V in the low current valve transformer and 22V for the amp at the same time or not (whithout modifications and calculations in the schematic, because iīm not able to do it) Thanks and sorry for my english |
#4 |
Hi, Miguel !
Tube buffer and power chipamp are 2 independent parts, tube PS voltage do not depend of chipamp PS voltage. You can use for tube even higher voltage then 35V, tubes like it. 22V for chip is OK. Don't use same PS for tube and chip. Zigis. |
#5 |
| Gainclone vs tube | navin | Chip Amps | 33 | 21st February 2006 04:47 AM |
| Gainclone with tube buffer | almu100 | Chip Amps | 2 | 20th February 2005 03:28 PM |
| gainclone with tube preamp | TomekZ | Chip Amps | 2 | 31st December 2004 09:12 PM |
| Is there a 'Gainclone' Of the tube world? | PHilgeman | Tubes / Valves | 28 | 8th August 2004 07:40 PM |
| Page generated in 0.08970 seconds (68.45% PHP - 31.55% MySQL) with 10 queries |
