| Chip Amps Amplifiers based on integrated circuits |
#2 |
To explain how it works in a way that you will understand it would take a very Long Time, it would be easier and quicker for you to take an electronics cource or to spend the Next 6 to 12 months Reading a LOT about electronics......
There are so many Things you have to Know before you can even start understanding how the curcuit works that even if someone were to explain the curcuit in Detail to you , you probably wouldn"t understand anything of what they had said..... A start would be to read the datasheet for the TDA2005 IC which is were the Curcuit comes from, but if you can"t comprehend the Info in the Datasheet you will definately not understand the Inner workings of the Curcuit..... Poeple spend Many Years Learning electronics before they can even Tackle designing the simplest of curcuits....... I personally Only understand the very Basics and I have been doing DIY Constantly for the Past year....I have designed quite a few curcuits but most of them either Fail or do not work out the way I want them to but I have gotten lucky on a few occations and was able to design some Fairly good performing audio curcuits but they were Probably a Fluke...... Good luck |
#3 |
Hi Bubba, I'm a recent convert to this stuff as well, this site has helped me through some difficult thinking........
http://www.allaboutcircuits.com/ Its an enormous amount to learn but its grouped nicely through the yellow links at the top of the page Good luck JB |
#4 |
Hi, go to the ESP site at
http://sound.westhost.com/articles.htm read all of the ones you think useful. then read the projects. then come back with questions (if there are any).
regards Andrew T. |
#5 |
I just started to learn about amplification too. What I found very helpfull as a start are Nelson Pass' Zen articles, explaining very simple circuits with simple words, well writen and entertaining.
The very first is here , the other can be found at www.passdiy.com have fun LC |
#6 |
Im in a similiar situation. Though I have built simple tube amps and line stages I have never done any solid state construction or design. These links are great! Any others related to construction techniqes? How about books? thanks in advance.
#7 |
Check out this thread too, about halfway down there's a tonne of good links. Helped me alot when I finally got around to reading all of it. 3 channel lm3875 help/advice Tristan
When I was young I really wanted a bicycle, I used to pray every night for god to bring me one. But as I got older I realized god didn't work that way so I stole one and begged for forgiveness. |
| help with learning | krish2487 | Solid State | 9 | 15th December 2008 06:03 PM |
| new learning | aardvarkash10 | Tubes / Valves | 1 | 23rd November 2008 07:47 AM |
| good book for learning the basics of tubes and tube amps | frajavcar | Tubes / Valves | 5 | 18th July 2008 07:33 PM |
| DHT learning | dsavitsk | Tubes / Valves | 3 | 27th September 2005 11:57 AM |
| learning how to do this | famine24 | Tubes / Valves | 1 | 23rd November 2004 01:47 AM |
| Page generated in 0.08799 seconds (77.89% PHP - 22.11% MySQL) with 10 queries |
