| Chip Amps Amplifiers based on integrated circuits |
hi guys....
i need op-amp that has high voltage input - up to 40V plus and 40V minus - total 80Vpp that has high input resistance and that is unity gain stable.... i need it as a voltage buffer - with unity gain folower any ideas.... i don't need almost no current driving capability but the input voltage has to be high and unity gain stable.... any ideas that are cheap and good (if cheap is possible).....
when you burn it - burn it good |
#2 |
o.k. - to clear things a little bit more....
i need opamp that is: - unity gain stable - has rail-to-rail input/output topology or at least common mode input voltage range and output swing must include the voltage range of the signal that is up to arround +/-40V...... so this opamp should be a monster kind of opamp that has very high voltage input and that will work as a unity gain voltage buffer...... help please ![]() question - what "rail-to-rail input/output topology# really means - what is that.????
#3 |
Extreme......
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
this is really extreme but this design does not have more than 8V at the input - i need +/-50V swing at the input and unity gain stable.....
#5 |
#6 | |
It is confusing to switch forums in the middle of a thread ... :-( |
#7 |
i am sorry Cliff....my apologies but.....i like to hear a lot of opinions......i hope you understand ...
you are helping - i appreciate this a lot and because of it THNX A LOT ![]() so far i know how to make this thing working with interconnetc cables....only have to figure out how to make it work with speaker cables up to 50-70W power amps....
#8 | |
this one looks interesting..... by now i have made a decision - i will try this approach with interconnect cables - if this works - i will try to make it work with speaker cables...... for interconnect cables i think that also OPA604 or OPA2604 might work nicelly too. ![]() i would like to suggest that we continue on this part of the forum so that our friend (and others maybe too) can follow more easilly... here is the link.... http://www.diyaudio.com/forums/showt...30#post1179330
| High voltage Opamp with power transistors | sivan_and | Solid State | 13 | 1st January 2009 10:42 AM |
| 6BY5 High Voltage & High Current Choke Input Design P.S. | snoopyma | Tubes / Valves | 7 | 28th June 2006 01:32 PM |
| High voltage OPAMP / PREAMP | hugeli60 | Solid State | 7 | 17th February 2002 08:03 PM |
| Low noise, high voltage input trannies... | Shaun Onverwacht | Solid State | 5 | 9th May 2001 05:36 AM |
| Page generated in 0.12582 seconds (56.01% PHP - 43.99% MySQL) with 11 queries |
