| Chip Amps Amplifiers based on integrated circuits |
power transformers 220 volts to 110 volts
Hi there, I was just wondering, there are a lot of cheap voltage transformers that convert 220vac to 110vac so you can go from european power to us power. I am not sure what is exactly in these, but if it is just a simple transformer, could you hook up the primaries to 110v ac and secondary output would be 55v ac? Thanks, Gary |
#2 |
they are just a 2:1 turns ratio mains transformer. If you run a 220Vac transformer on 110Vac you will reduce the VA rating to about half the 220Vac value. i.e. you will overheat it if you try to take the original power out of it. If you convert a dual primary 110+110 transformer to run on either supply you can obtain the full VA rating from both supply voltages.
regards Andrew T. |
#3 |
The other thing to bear in mind is that a lot of these are autotransformers, thus have no isolation and are dangerous to use on their own.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
I've built two such units for 6moons publisher and he is very happy with them: http://www.6moons.com/audioreviews/240_117/240_117.html
Additionally, you can implement balanced power configuration, which brings further improvement over regular step down setup.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| how to use 30 volts DC instead of split power Supply | ali_moinuddin | Pass Labs | 5 | 2nd April 2008 11:34 PM |
| power supply question.... too many Volts? | akimball442 | Tubes / Valves | 3 | 18th February 2007 05:12 PM |
| 16 volts 3A regulated power supply help | sunny | Power Supplies | 30 | 3rd November 2006 12:51 AM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 01:10 AM |
| noob/ish question on volts and power | psychosteve | Solid State | 4 | 12th October 2004 03:50 PM |
| Page generated in 0.07824 seconds (71.91% PHP - 28.09% MySQL) with 10 queries |
