| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I plan to make a new good chipamp for our DIY Audio club in Turkey. It will have to be exactly in audiophile quality. I want to have 100W at least per channel and will a be stereo power amp. Also I want to drive both 4, 6 and 8 ohm loads with it. I thought the parallel clone of LM3886 would suite for that project. However, as I calculated on Overture Design Guide; 6 and 8 ohm is not working with parallel configuration. Does anybody has any idea about that? Can I work with 6 and 8 ohms with parallel configuration? Best regards,
Best regards, Ozgur |
#2 |
don't let others tell you otherwise, 1*LM3886 can drive 4 ohms resitor, I don't see any reason why parallel 3886 won't not drive 4 ohms.
The only reservation I give is is that some speakers are general capacitive in nature, sometimes 4 ohms speakers(eg MTM configuration) due to capacitive loading will drop below 4 ohms, at times 2 ohms, in this situation 3886 may not be able to handle with ease. If you have this problem, then you can connect a parallel resistors and inductor circuit inseries with the 3886's output, see website below and down LM4780(dual 3886) applications note for details of how to do this. http://www.national.com/pf/LM/LM4780.html |
#3 |
In fact, the problem is not driving lower values.
The problem is driving higher value loads. If I paralelled two LM3886 and drive a 8ohm load then the load looks 16ohm for each chip. I ask; is this a problem?
#4 |
Not in the slightest. It is only for hard loads (meaning lower impedance) that you should worry about the chip. In other words, if it can drive a 4 ohm load, it can drive a 6, 8 or 16 ohm load more easily. The reason for this is that during higher loading (lower impedance loads) the chip must drive more current, making the overall power required from the chip greater.
David |
#5 |
Thats ok.
But I have another question. I plan to use regulated supplies. And have the maximum output value. So if I use LM338 for regulator, and apply 38 or 40v per chip (TA case) that causes any problem (for 6 ohm load)..
#6 |
Is 6 ohms your minimum impedance or a nominal value?
Would a woodchuck bother to chuck MDF? |
#7 |
No thats a general using project. Users may apply loads in 4 ohm to 8 ohm range.
#8 |
A Paralell LM3886 into 8 Ohms means that each Chip is Driveing 4 Ohms which means you should have your PSU in the +/-24v range.....
When driveing 4 ohms each chip will see 2ohms which will probably heat the chip up a Bit because Lower impedances are harder to drive so make sure you have a Large Heatsink...... Cheers |
#9 |
Wrong!
If you paralelled two LM3886 and put a 8ohm load to the outputs then every chip drives 16ohm load...
#10 | |
David |
| LM3886 in parallel | Denis.BR | Chip Amps | 11 | 12th August 2009 07:16 PM |
| LM3886 parallel PCB's | jmillerdoc | Chip Amps | 0 | 27th May 2009 08:26 PM |
| LM3886 Parallel Use | Rachel | Chip Amps | 71 | 2nd July 2006 04:24 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Bridge/Parallel LM3886 Amp | Toucan | Solid State | 2 | 15th March 2003 11:46 AM |
| Page generated in 0.10310 seconds (80.90% PHP - 19.10% MySQL) with 10 queries |
