| Chip Amps Amplifiers based on integrated circuits |
Hi all!
I found an alps pot in an _old_ and broken Yamaha integrated amplifier. I was planning on using it as a passive preamp for my dual mono gainclones from audiosector (premium LM3875) Does anyone have any experiences with this pot and my amps? Best regards Henrik |
#2 |
picture of side
#3 |
Hi Henrik and welcome to the forum!!
It looks a lot like a 'Black beauty' except that it it seems to be for more than two channels and maybe five. Was the Yamaha integrated a surround amp (for home cinema) or is their a balance control? E.G. Does the outside dial control channel balance and the inside controls volume. The Black beauty is quit an expensive pot. I have the cheaper 'Alps Blue' and that is very good. I haven't tried the 'black' yet. The 53K should be suitable. Do you know your source impedance? Martin. |
#4 |
Hi Sonusthree
Thanks for answering! Yes, the outer ring is for balance control and the inner is volume, The amplifier from which I got it is a big stereo amp, 30W class A or 200W class something (selectable) Are there documentation available for these pots? I've tried to search, but my google-fu is a bit low.. ![]() Henrik |
#5 |
I've heard somewhere before that the 'Black beauty' is discontinued but I'm not exactly sure.
I think that your pot is a probably a custom model based around the RK27 on this page: Alps Japan Potentiometers Google is your friend.
#6 |
How old is the pot???
#7 |
_very_ old, ill bet it's older than 15 - 20years...
The model it's from is "Yamaha neutral sound amplifier CA-2010" |
#8 |
here's a link for the amp: http://www.hifigoteborg.se/Yamaha%20CA-2010%20spec.htm
in swedish... |
#9 |
That amp looks at least 20 years old so the pot may be a little worn and noisy but there is no way to know except to try it.
It's quite easy to wire it up and test so why not make a quick prototype. It might just sound fantastic!!
Martin
#10 |
Yeah.. as I said it is _old_
![]() I'll try to wire it up, but I'm still looking for a wiring-diagram.. I know the top two rows are for the balance, but I'm not sure I'll be using that.. or..? Henrik |
| Alps Pot 4 Terminals | picchiatello | Parts | 2 | 6th March 2005 08:22 PM |
| ALPS Pot | Brap | Tubes / Valves | 5 | 8th April 2004 12:31 PM |
| WTB:alps | sma | Parts | 1 | 13th December 2003 06:10 PM |
| ALPS pot | Mikael Abdellah | Parts | 6 | 21st April 2003 12:31 AM |
| Alps pots in the UK? | Kram | Parts | 4 | 18th March 2003 09:15 PM |
| Page generated in 0.09251 seconds (84.34% PHP - 15.66% MySQL) with 11 queries |
