Normal temperature of LM3886 - Page 3 - diyAudio
Old 27th June 2013, 09:17 PM   #21
Robert Kesh's Avatar
Originally Posted by jaycee View Post
you might want to check for good thermal coupling with the heatsink. In doubt, sand the heatsink with some fine sandpaper to make sure it's flat. If you are using isolated heatsinks (a good idea!) Mica will do but make sure it's quite thin, and you have to use paste thinly.
Personally, I used the grey "sil pad" things with mine (the TO3P ones fit just fine) and i dont have a heat transfer issue. Saves the mess of paste, too.
this was my first thought. one slight bump where you drilled a hole and the coupling is gone
normal X-Amp uli Pass Labs 42 19th November 2010 06:31 AM
Is it normal to think this way? gain wire Instruments and Amps 3 16th October 2008 11:09 PM
What's a normal temp for LM3886 on 40+40 DC? danielwritesbac Chip Amps 4 22nd January 2008 06:51 AM
Is this normal? A_Reef_Scene Multi-Way 2 7th March 2007 06:51 PM
Toroid normal temperature. K-amps Parts 4 28th February 2004 06:29 PM
Copyright 1999-2017 diyAudio
