| Chip Amps Amplifiers based on integrated circuits |
Attached is THD+N vs Output Power plot of parallel configuration from Overture™ Series guide. Does it mean parallel configuration is unusable over 100W (due to high THD).
Thanks Yusuf |
#2 |
the curve shows the amplifier clips above 100W(closer to 110-120W) hence the THD rises rapidly.
Note the power supply is at +/-35V, if the PS is less than +/- 35 the power output will decrease. |
#3 |
In parallel 4 ohms means each IC in a 2 chip design sees 8 ohms. At this point it is a thermal limitation. National shows what can be done with a consevative design (meaning no fan on the heat sink and sine waves all day long). So if you want to use a bigger heat sink or since music is less demanding than sine waves you can get more power. You just need to boost the supply voltage higher. I have an amp I built that runs more like 140W but it will over heat (LM3886 protection circuitry kicks in) with sine waves. I have run it for hours doing a DJ job with out any problem. The maximum supply voltage from the LM3886 datasheet is +/-42V with a signal so you can use up to this level but you will need to use a bigger heat sink, a fan or just run music to keep it cool enough. You can only get about 60 - 70W maximum per LM3886 no matter what configuration you do or load. Just the physics limitations.
-SL |
#4 |
You don't belive me, Yusuf ?
| Maximum output with tda2050 | pra3718 | Chip Amps | 11 | 10th August 2009 05:42 PM |
| Lm4780 problem, 3.5V on output when power on... | jaste | Chip Amps | 11 | 1st April 2008 05:23 PM |
| Maximum voltage for LM4780 | G.L. Tirebiter | Chip Amps | 5 | 6th March 2005 10:06 AM |
| LM4780 instantaneous peak output power capability | percy | Chip Amps | 0 | 18th October 2004 04:15 PM |
| Page generated in 0.07932 seconds (71.76% PHP - 28.24% MySQL) with 11 queries |
