Old 30th March 2007, 04:23 PM   #1
mr.duck is offline mr.duck  United Kingdom
Default Gainclone, mains filter, and PSU inductance
Hi, I am planning to build a "classic" gainclone with LM3886 and 1000uF caps. Trying to make it very small and relatively cheap, hence the simple PSU.
I thought it would be a good idea to use a filtered IEC inlet with an earth choke to remove any high frequency rubbish on the mains, and to stop noise getting in through the safety earth connection (since one of these filters will easily fit in and are not too expensive). But then remembering the point of using the small smoothing caps in the first place is for a low inductance power supply. I was wondering if the filter will add inductance and could it do more harm than good to the sound quality?
Old 30th March 2007, 04:38 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
I would suggest you try the amp with and without the IEC filter in place. If you don't like it with the filter in place you can always use it for another piece of equipment.
Brian
mains filter ccereda Power Supplies 35 29th January 2012 11:26 AM
Relationship Between Inductance And Current In Filter Choke mark845 Tubes / Valves 2 6th December 2006 11:58 AM
Mains filter QS Bassivus Parts 7 19th September 2006 07:12 AM
mains filter? karma Solid State 1 14th June 2004 04:10 PM
mains RF filter habana Analogue Source 3 21st October 2003 11:37 PM
Page generated in 0.05661 seconds (73.91% PHP - 26.09% MySQL) with 10 queries
