Old 27th March 2007, 12:02 AM   #1
Default on/off spark
Could someone explain why I might want to put a cap across my on/off switch? I realize it would probably quench a spark, but so what. If I need/should have one, then what would be an appropriate value/type? Thanks for any inputs.
-Bob
Old 27th March 2007, 12:09 AM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Sparking or arcing degrades the quality of the switch contacts. When you say switch are you referring to a mains switch such as one you would put in series with the primary of a transformer?
Brian
Old 27th March 2007, 12:21 AM   #3
Exactly -- in series with primary, 120VAC. Would you know what is a good selection for something like this?
-BG
Old 27th March 2007, 12:25 AM   #4
I_Forgot's Avatar
Sparking in the power switch will eventually destroy the contacts and the switch will fail. This is a bigger problem with toroidal power transformers than EI core transformers due to comparitively higher in-rush current. Amps and any other equipment that use big toroidal power transformers often have thermal in-rush current limiters, timer resistor/relay circuits, or big triacs to switch the power. Big in-rush current can also trip circuit breakers which can be really annoying.
I_F
Old 27th March 2007, 01:06 AM   #5
Thanks for your comments. I am using 2-800VA to provide for 8-LM4780's (parallel output). Some people think I am sick. I have a 120vac DPDT 10A relay across a 30ohm 25W, relay coil (one each toro) will not energize until the toroids have surged through the resistors, one for each toroid. Now that you guys have got me thinking, I may not need a cap across as the surge should be over before the relay closes.
Why 8, you ask? I wanted 8 for speaker design, wanted to be able to drive 4 ohms and thought it would be worth it to do a decent job and I could always use it for a home theater. The 2 ch proto I built sounded better than my $2700 Yamaha DSP.
-BG
What you think about Ayon Audio Spark SE 6C33 tube 22 W mario2005 Tubes / Valves 0 20th January 2009 09:58 PM
PA Speakers spark? Advise Please! htgeek PA Systems 3 4th September 2007 01:12 AM
Relay spark problem Dxvideo Chip Amps 26 30th July 2007 07:32 PM
Page generated in 0.09794 seconds (70.13% PHP - 29.87% MySQL) with 10 queries
