| Chip Amps Amplifiers based on integrated circuits |
The parts used for a GC are very small, I would imagine they're also sensetive to heat build-up, what should I look for in a soldering iron?
I have one that I used for installing my car alarm and remote start, but the tip is very large. If I can find a smaller tip, should I consider it?
Got Bass? |
#2 |
A 25-50 watt iron is about right. Most decent irons have tips that can be replaced. If not, it's a cheap iron. You could always grind down the tip with a file to give a nice point. Don't be too concerned, most of the components aren't that sensitive to heat, mostly the capacitors and the chip itself, but decent technique won't put them anywhere near their limits.
Listen to the music through the stereo, not the stereo through the music. |
#3 | ||
Got Bass? |
#4 | |
#5 |
jpg: Solid advice. In my youth, I used to do just that(file the crud off the tip to make it nice and shiney) until my uncle told me I should use a wet sponge to clean the tip. I had filed off the iron plating, and sure enough it started to disappear. The roson in the solder eats copper like crazy.
#6 |
I actually do exactly that....I buy these Cheapo $1 soldering irons and then Grind the Tip down to a sharp point and use it that way.....Each iron lasts me about 2 months and then I just replace it with another $1 Iron.....They actually work surpriseingly well....
#7 |
SO YOU SAY A SPONGE WILL HELP FROM THE TIP EVAPORATING? IT SEEMS THAT EVEN WITHOUT SHARPENING IT DOWN IT STARTS TO GET SHORTER. IS THERE NO WAY TO PREVENT THAT? OR DO MORE EXPENSIVE TIPS LAST LONGER?
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#8 | |
Buy a quality soldering iron. I have three solderinh irons. All 3 are WELLER (15W, 25W and 50W). They are 17, 10 and 25 years old, all with original tips (a dozen of them - for different purposes and temperatures - from SMD and SOIC chips soldering to soldering of steel metal sheets). I clean them only with dry, dense linen cloth while hot (quick stroke over the tip is all they need). These tools saw a lot of heavy duty use over the years without deterioration. Wet sponge is out of question because fast cooling makes tip's protective surface material to crack. If you plan to avoid stress in your hobby, invest in good tools. WELLER has my recomandation for quality and longevity. |
#9 |
These ones sell in Europe for around EU20.- ![]() http://www.aoyue.com/en/Product.asp?...LE%20SOLDERING Full blown genuine Chinese but excellent quality We have several in our production workshop and the tips last very long. After half a year of continuous use they are still in perfect condition.Cheers
#10 |
Best thing to clean a hot tip is blue jeans
Spend more time cleaning and tinning than soldering. That's always produced my best results. Whether using good or cheap.
Poor stereo mix? Switch to mono! Perfect. |
| looking for a soldering iron | Shpoop | Parts | 38 | 8th September 2008 02:58 AM |
| 42 VAC soldering iron | Jan Dupont | Parts | 2 | 8th August 2008 03:48 PM |
| soldering iron | jaudio | Parts | 15 | 17th March 2006 07:22 PM |
| For those of you in the UK who need a new soldering iron | 5th element | Parts | 2 | 26th March 2004 10:58 AM |
| Page generated in 0.13484 seconds (70.68% PHP - 29.32% MySQL) with 10 queries |
