| Chip Amps Amplifiers based on integrated circuits |
I constructed the RIAA phono preamp from ESP site. http://sound.westhost.com/project06.htm (the single supply one - bottom of page) The preamp board is mounted inside the turntable and is sounding fine initially. But after about 20 to 30 mins of operation, it starts giving out strange crackling noises at irregular intervals. I dont believe the problem to be attributed to any rumbling. Could it be because I am not using a regulated supply (about 18V) at PS output. Just the 13.2V from output to Bridge rectifier to a 1000uF Electrolytic. Or what else could cause the problem?
Regards, Din |
#2 |
Could be a dodgy joint. A regulator would be a good idea. Also download the NE5332 datasheet, the circuit does not show the PS decoupling capacitors needed. /sreten.
#3 |
Electrons are yellow and more is better!
A good RIAA amp must have a regulated _good_ power supply. Remember, you want to amplify microvolt signals as the weakest.
Despite from that, have you checked all solder joints? How about voltage ratings of your electrolytic caps? Anything gets hot?
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#4 |
Thanks for your responses , peranders and sreten.
I did not check so far for any thing getting hot - this is enclosed within the turntable box and I am yet to open it. I wanted to get inputs on possible causes before looking into it.
Regards, Din |
| help needed with noise in phono preamp | duderduderini | Tubes / Valves | 22 | 31st May 2007 03:35 PM |
| Super fast, low noise phono preamp | dioklecijan | Analogue Source | 30 | 19th July 2004 09:52 PM |
| Who's measured the noise on their RIAA preamp? | CeramicMan | Analogue Source | 20 | 19th February 2004 06:35 PM |
| RIAA phono preamp using single ECC83 | DJG | Tubes / Valves | 19 | 29th March 2003 02:27 PM |
