Gainclone...No gain, YES pain.
Old 13th January 2003, 09:49 PM   #1
JAZZ2250 is offline JAZZ2250
JAZZ2250's Avatar
Default Gainclone...No gain, YES pain.
I tried gainclone with gain=1, and it got pretty hot in a very short time. I think, according to the others' comment in this thread, it is due to an oscillation. I tried both T and TF package, and both of them got hot. Actually, I was thinking to use a gainclone as a power amp without any gain, but it doesn't seem to be possible because of the nasty oscillation.
What I'm thinking right now is that if I set the gain of gainclone to, say, 20 and put a voltage divider at the input before the coupling cap, and hook it up to a tube preamp with a maximum gain of 20 dB, would it be worth trying? As I heard, the main benifit of using tube amps is at the voltage amplification. In the configuration stated above, voltage amplification is done first at the tube stage, and signal gets lower by the voltage divider, and then voltage is amplified again by gainclone. In such a case, there wouldn't be any benifit of using a tube line stage, IMO.
I would like to know what others think about this configuration. Is it gonna be worth trying or a waste of time and money?
Thanks in advance.
Old 13th January 2003, 10:14 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Gainclone...No gain, YES pain. Send a message via AIM to Peter Daniel
Doesn't make much sense, such configuration. First you amplify, than attenuate and then amplify again.
To order kits contact me through forum mail.
Old 13th January 2003, 10:21 PM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
The only way to get gain around unity from these chips is to use inverting topology.
cheers
peter
Old 13th January 2003, 10:25 PM   #4
JAZZ2250's Avatar
Default inverting topology?
Could you explain more about it? Thanks.
Old 14th January 2003, 12:18 AM   #5
JordanG is offline JordanG
JordanG's Avatar
Default Re: inverting topology?
I'd recommend reading this. It provides a nice introduction to the inverted gainclone. Also, here is a forum where people like to talk about and tweak IC based amplifiers.
hope that helps
--Jordan
Old 14th January 2003, 12:30 AM   #6
tiroth is offline tiroth  United States
Amplify, attenuate, amplify is just going to raise your noise floor.
You realize that the LM chip is not spec'd stable with gain < 10?
Old 14th January 2003, 12:46 AM   #7
JAZZ2250's Avatar
Yes, I realized why the gain less than 10 is not recommended by NS. Definitely it doesn't seem to be a good idea to run the amp with such a low gain though I cannot hear the oscillation. It should also be applied to non-inverting configuration, right? I gotta try it.
Mmmm, then I'll have to think about which power amplifier, which is simple to build, will go well with tube preamp. Another tedious search is about to begin now. Any recommendation, please?
Old 14th January 2003, 12:52 AM   #8
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: Gainclone...No gain, YES pain.
Then you did badly wrong. Big booboo. You CANNOT get unity gain in non-inverting topology, you can extremely easily get unity gain in inverting mode. Simply use a pair of 220k Resistors, one from the Amp input to the inverting input, the other from the inverting input to the Output.
NOW observe the magic. Place a 22k resistor between the inverting input and ground. Then place an 18k resistor between the positive input and ground. Unity gain and stable. Easy as pie.
Sayonara
PS, this same sort trick lets you use the OPA637 as I/V converter without osccillation. It sounds notably better than OPA627 in this position but is not unity gain stable....
Old 14th January 2003, 01:26 AM   #9
JAZZ2250's Avatar
I used all 47k resistors. Let me see what I did wrong... I think I didn't use one resistor which is 22k in your recommendation. I directly connected the signal to a resistor which is connected to the inverting input. I thought the one (22k in yours) was not necessary because inverting input could be thought as a virtual ground. Wrong? Sorry for my poor knowledge, but I thought I had read it somewhere. Do you think putting that resistor will make a difference? Please let me know, Sayonara Sang.
Old 14th January 2003, 06:15 AM   #10
analog_sa's Avatar
If i may volunteer a reply the 22k resistor is there to provide stable dc reference. A problem of 'textbook' inverted amps is that the offset voltage varies according to the dc resistance the inputs see relative to ground.
cheers
peter
Gainclone...No gain, YES pain.Hide this!Advertise here!
Help with GainClone gain setting johan851 Chip Amps 35 15th February 2008 05:33 PM
Inverted GainClone's gain question? 5150ed Chip Amps 15 10th July 2006 08:12 AM
The Gain in a GainClone? Mmne Chip Amps 11 26th April 2006 11:40 AM
New Gainclone with no gain: help requested SRMcGee Chip Amps 29 8th October 2004 06:31 AM
