Good PSU for a 6.1 LM4780 chipamp
Old 18th March 2007, 09:57 PM   #1
mangrovejack is offline mangrovejack  Australia
Question Good PSU for a 6.1 LM4780 chipamp
Hi guys,
I'm going to build a 6.1 amplifier from the LM4780 boards that Veteran has listed on the for sale section. Each of the 6 normal channels will use half of a LM4780 (60W) and one of the boards will be used for a sub (120W).
In terms of a power supply, I was thinking of either 2 or 3 smaller transformers rather than 1 gigantic one.
Other than that, I'm not sure what a decent supply would be. Anyone built anything similar and want to share their ideas? I'm open for anything as I haven't bought any of the PSU components yet.
Thanks.
Old 19th March 2007, 12:09 AM   #2
Bassterror is offline Bassterror  Germany
Hi
I've got some of them to and i want to go for 5.1.
I've built a test amp on a piece of wood so far.
4Ohm or 8Ohm Speakers?
I'm not going to use a LM4780 for my .1 Channel. I'm loocking for a second hand PA-Amp instead.
The longer I think about paralleled LM4780 the more I dislike it.
One LM4780 has only about 150% of the heat transfere area of a LM3886. And If u got to isolate it from the heatsink, u wont find i fitting kapton or mica isolation pad. And silcone sucks.
And a subwoofer will need a good damping factor. A paralleled Chip will need resistors on the output -> not good...
I whould use one single 600-800VA Toroid and one rectifyer per board.
18V for a 4Ohm load or 24V for 8Ohm.
And if u use one board for ur sub, I'd spend it another transformer, about 200VA.
Any Idea for a decent case?
Greetings,
Stephan
Good PSU for a 6.1 LM4780 chipampHide this!Advertise here!
First chipamp build need advice lm4780 chevy1965usa Chip Amps 10 5th March 2009 10:44 AM
my first lm4780 chipamp works and wow!! gbolly Chip Amps 7 25th November 2008 08:49 AM
new ChipAmp.com website - LM4780 kit and more BrianGT Chipamp 97 29th April 2008 03:29 AM
chipamp lm4780 components garbage Chip Amps 12 14th November 2004 02:14 AM
