| Chip Amps Amplifiers based on integrated circuits |
Hey guys, i want to know which is the name of the tool to bend 1-2mm metal foil.
I want to purchase that machine (hand/manual) to build some cases. But my english is not good and dont know how named it to search the web for the price, hope someone can help me ![]() i want an cheap tool |
#2 |
It is sometimes called a metal brake IIRC.
Any technology sufficiently advanced is indistinguishable from magic |
#3 |
http://www.southern-tool.com/store/m...pan_brake.html ... and you can make its own stand with it ... shipping on this stuff can be another arm and leg ... best suggestion is compare prices on ebay, then find a comparable gadget close to home and jump in the ol' pickup and go get it.
Over compression is a problem with modern CD recordings |
#4 |
Magneto the Gravity Man
http://www.machinemart.co.uk/shop/pr...s/brand/clarke
or make your own http://cgi.ebay.com/Rorty-Sheet-Meta...QQcmdZViewItem Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#5 |
An older tool for the same job is called a brick!
#6 |
I built a aluminium chassis box (1.6mm thick) at home. No special tools for bending. I used the door edges to hold the sheet and hand bent the sheet.
Crude !! but doable.
Regards, Din |
#7 |
ive used a nice vise. you just clamp where you want to bend and use a board (i used a large piece of wood) to press against it at the clamp, and it made a nice bend.
#8 |
Please, look this.
It is simple et inexpensive!
#9 | |
Looks ok, but you used some machine to bend the aluminium? |
#10 |
Sorry, I don't speak well english.
1) the front and rear are commercial-outlined aluminum (www.alfer.com) 2) the fund is an aluminum plate with L profiles and rivets 3) the top is an aluminium plate with bi-adhesive tape 4) I attach an explanatory sketch and, then, other pics. GOOD LUCK !!!! |
| The way to build a chassis | Peter Daniel | Everything Else | 60 | 27th November 2010 01:08 PM |
| What d'you put in the PSU chassis, and what in the circuit chassis? | andyjevans | Tubes / Valves | 5 | 14th December 2007 11:41 PM |
| How to star ground to Chassis without a Chassis?? | Minion | Chip Amps | 10 | 5th November 2006 04:28 PM |
| Where to get chassis or chassis parts in Vancouver? | Prune | Parts | 1 | 7th July 2004 05:37 PM |
| Anyone use a old Hayes 14.4 Aluminum chassis to build a GG? | JCoffey | Chip Amps | 7 | 26th August 2003 12:10 PM |
| Page generated in 0.14311 seconds (59.19% PHP - 40.81% MySQL) with 11 queries |
