| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I found some BYW80-200 (ST) and i want to use them for my GCs rectifier. Its too hard to find MUR8x0 series in Turkey. As i examined BYWs datasheet, the specs are very like to MUR diodes. Does anybody use that rectifiers? May i use them instead of MUR?
Best regards, Ozgur |
#2 |
I can see no reason why it wouldn't work.
Just give it a try. /Hugo |
#3 |
Yea i think the same way. But i want to be sure, any DIYer tried it or not?
#4 | |
I have used them in my amplifier power supply (500VA, 88,000uF) so they will be more than adequate for a gainclone I think. I was recommended the MUR but they were too expensive so I used the BYW80-200 from Ebay. I got the idea from this page: http://www.hificollective.co.uk/components/diodes.html I used parallel pairs at first but found that to be completely unnecessary. I used some small clip on heatsinks. 35nS is very fast. I cannot honestly comment on the 'sound' of these diodes because I also increased and updated the capacitance at the same time. But my amplifier now sounds better than ever! Picture taken before removing parallel diodes: |
#5 |
Hmm.
Should i use them with heatsinks? I will use them under 40VAC and will sink 3A per rail max.
#6 | |
One of my worries was the large currents that flow when first switching the amp on and charging the capacitors. I use 88,000uF so I use large diodes with heatsinks just to be very safe. I don't like to take risks with power supplies but I may be trying too hard!! Regards, Martin.
#7 |
Why not?
I can use the small heatsinks for 78XX series. But my snubbers are too small if compares to yours. I use only 4x4,700µ on each rail! And 2,200µ's on amp board.. Does that cause any hum? And another question; should i put parallel hundreds nF caps to diodes? Because i saw this application on many GC psus.. In fact i dont know the reason.. Thanks.
#8 |
Did it Himself
You can get away without heatsinks, but unless you are stuck for space it would be better to use them.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#9 | |
The size of your capacitors are a personal choice. Some people believe less is better with gainclones. I think that, for amplifiers in general, more is better for low frequencies. I do not own a gainclone though so what do I know? I believe the 100nF caps (on the diodes) help to suppress any high frequency switching noise. You can probably see from my picture that I now have spaces for these since removing the parallelled diodes. I will definitely be trying it very soon!! I'll let you know if I hear a difference. You should try it too!! It is cheap, quite safe, and can be removed easily. This is what DIY is all about!! Good luck, Martin.
#10 |
So I will connect my diodes to small heatsinks.. Thats ok.
I asked you 100nF caps in parallel because i have some worries that if I put 100nFs in parallel then they causes any reverse current leakage on rectifiying line. But I am not sure on that! Thats only a foreboding. Thanks again.
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 6CJ3 rectifier or 6D22S rectifier | 56oval | Tubes / Valves | 10 | 19th April 2007 09:48 AM |
| 81 Rectifier | Diy martin | Tubes / Valves | 4 | 14th January 2006 01:54 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.13519 seconds (70.92% PHP - 29.08% MySQL) with 11 queries |
