Hi, I am building a Bridged/Paralell Chip amp useing 2 LM3886 Chips but I am haveing a Major problem Isolateing the Chips from the Heatsink......
I have the 2 Chips mounted to the Same aluminum Heatsink and I am useing Silicon Thermal Pads and a Bolt to Fasten the Heatsink to the Chips going through the Hole provided on the Chip ,and I have a Rubber washer between the head of the Bolt and the Chip......
The Problem is that when I use my DMM I can see that there is still a electrical connection between the -v Rail and the Heatsink It"s self......I do not see how it can be unless the Bolts threads are touching the Inside of the mounting Hole in the IC??? But how do you stop this??
I have even Tried Painting the the inside of the Mounting hole but there still seems to be an electrical connection from -V to the Heatsink......
I usually use the Isolated versions but this time I couldn"t get them so I have the un-isolated version......
How do I stop this from happening??
Would it burn out the Chips if they were not Isolated from each other?? I don"t think it should because they are both recieveing the Same -V, It"s just if the heatsink comes in contact with 0v or the +v rails that the short curcuit would orrur...Right??
I was wondering if I can"t fix this problem would it work as long as I made sure that the Heatsink didn"t touch Ground or +v???
Thanx a Lot.....
Cheers
Thanx a Lot.....
Cheers
I use to experince the same problem as you do when I was building an amp using transistor based on TO3 package.
You can do the following:
1. repalce the rubber isolato with an elongated plastic isolator between the bolt and chipamp. I think you can still find them. You may still need to adjust the chipamp so that the is no electrical contact.
or
2. use a metal bracket that can cramp to the body chipamp with 2 screws at opposite end, refer to this site:http://www.shine7.com/audio/bpa300.htm
as an example.
hope this helps..
or
as an example.
hope this helps..
use the insulating bushes, they use in transistor mounting kits.
http://www.maplin.co.uk/module.aspx?ModuleNo=30386&doy=17m3
and make shure that you didn´t use a conductive cooling pad
As long as your heath sink is isolated from ground ( and chassis ) and V+ you don't need to use anything between the chip and the heath sink ( except some thermal conductive paste ) and you get better heath transfer . This is what i did with my amp and I've had no problems... Or you could use the TF version of the chip.
I would recommend against merely painting the bolts. This may not be a long term solution, you should either isolate the heatsink from the chassis (if metal chassis) since 2 chips using same supply negative rail will not be a problem in electrical contact with same heatsink, or use the proper isolation bushing as already mentioned.
- Chip Amps
- LM3886 Isolation Problem......
