Sound card as source, two different monoblock amps.
Old 16th March 2007, 06:18 PM   #1
beerman is offline beerman  United States
Default Sound card as source, two different monoblock amps.
Just brainstorming:
Most PC 5.1 sound cards use a single stereo 1/8" jack for center channel and subwoofer output.
I thought about a single-chip for the center channel, and either a parallel or bridge/parallel for the subwoofer, for more power.
They'll probably be on two different power supplies, for differing voltage requirements.
Would two different power supplies cause a problem with the common ground 1/8" jack?
Got Bass?
Old 16th March 2007, 06:34 PM   #2
the two monoblocks are effectively separate.
Split your output into twin feeds and send them to the amps.
regards Andrew T.
Old 16th March 2007, 06:38 PM   #3
Does this require additional active components for isolation, or is it a matter of splicing the common wire and not worrying about it?
Got Bass?
Old 17th March 2007, 09:28 AM   #4
if your monoblocks are separate then it matters not that they share a return connecton at the stereo outlet plug.
Yes, just take a feed from each stereo output pin and a return to the ring.
regards Andrew T.
Old 17th March 2007, 07:05 PM   #5
Excellent! Thanks for the reassurance.
Got Bass?
Sound card as source, two different monoblock amps.Hide this!Advertise here!
FA: Two Eico HF-22 Tube Ultralinear Monoblock Amps joe-electro Swap Meet 0 4th June 2009 09:22 PM
FA: Eico HF-22 Monoblock Tube Amps joe-electro Swap Meet 0 29th May 2009 02:27 PM
Why would the frequency response vary so much on a pair of Monoblock amps? sgerus Tubes / Valves 10 11th July 2008 05:53 PM
Source for Adcom GFA-565 Monoblock Parts tfong Solid State 4 10th October 2006 07:42 PM
FS: Fairly modified ASL Wave 8 tube monoblock amps Saurav Swap Meet 0 8th July 2003 05:34 AM
Copyright ©1999-2017 diyAudio
