| Chip Amps Amplifiers based on integrated circuits |
I am interested in building a chip amp. I am more interested in simplicity than great sound. Is there any consensus on what designs work best?
I think this forum could use a sticky on the various designs out there.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#2 |
I suggest that you consult the data sheets and ap notes. They are full of circuits designed by the guys who designed the chips. What you may think are "extra" or "unnecessary" components are there for good reason. Leave them out and you risk burning up your amp and maybe your speakers, too.
I_F |
#3 |
To get good sound as well as simplicity my experience is as follows:
1. Hard wire your Chipamp. The components should be a close as physically possible. 2. Use good quality components, resistors and capacitors, don't have go over the top. 3. use minimun number of components, the circuit from National data sheet is suffcient, you don't have to implement the muting part. 4. Depending on your preamp(tube or solid state), the input impedance to chip amp is important. cheers.. |
#4 | |
You have asked a very loaded question here. You are probably going to get about 1000 different opinions now. Some of them will be rude. Some won't. If you are looking for simplicity you should probably try one of the kits that are currently available and go from there. http://audiosector.com/ http://www.chipamp.com/
Gavin |
#5 |
diyAudio Moderator Emeritus
I'm getting very good results with this configuration:
http://www.diyaudio.com/forums/showt...71#post1108371 I'm using the LM3875 and the OPA2134 with the OPA2134 supply derived from the higher voltage rails. Sounds great in its current form. It may even sound better with a separate supply for the dual op amp.
Brian |
| Definitive SuperTower Clone - Anyone? | 69stingray | Multi-Way | 6 | 20th November 2009 04:39 AM |
| Connecting Virtual Ground Circuits with True Ground circuits?? | Minion | Solid State | 1 | 12th February 2007 01:28 AM |
| Research on tubes and circuits simple circuits | Cazcotty | Tubes / Valves | 6 | 16th June 2006 12:50 PM |
| Definitive sub problems | zarcon6 | Subwoofers | 1 | 13th December 2005 09:36 PM |
| 85 powersupply circuits 58 charge circuits | gev | Power Supplies | 0 | 31st July 2005 11:27 AM |
| Page generated in 0.09007 seconds (70.11% PHP - 29.89% MySQL) with 10 queries |
