Old 10th March 2007, 05:06 PM   #1
Default LM1875 noninverted
I want to ask you guys if this would work!!
Old 10th March 2007, 05:31 PM   #2
bigwill is offline bigwill  United Kingdom
Positive feedback?
I am not an expert but I don't think this will work due to the way the feedback is wired, but I'm willing to accept that I may be wrong.
Old 10th March 2007, 05:54 PM   #3
phn is offline phn  Sweden
phn's Avatar
That's basically an inverted design with the chip mounted wrong.
I don't think it will work.
Old 10th March 2007, 05:58 PM   #4
What should then be changed to have it noninverted. Maybe just without the feedback??
Old 10th March 2007, 06:09 PM   #5
phn's Avatar
http://www.geocities.com/rjm003.geo/...io/diy_gc.html
Old 10th March 2007, 06:15 PM   #6
Put R2 between the output and the - input (pins 2 and 4). Connect R1 between the + input and ground; connect the right side of C1 to the + input. The gain will be 1 + R2/R3 = 21
Old 10th March 2007, 06:31 PM   #7
I did that! Thanks! Just made a pcb. I have just one more question: how does reflect an inverted input on output in audio way. I know that signal is inverted but how is than amp like this heard. Maybe a stupid question but I really don't know this.
Old 19th April 2007, 03:35 PM   #8
I Just made this amp today.It sounds good! I come from China !
This amp can work !
Old 20th April 2007, 12:07 AM   #9
AndrewT is online now AndrewT  Scotland
This amp can work !
if you made this amp today then you are telling us lies about how good it sounds and that it works!!!
A chip amp arranged for inverted mode but with swapped inverting and non-inverting input pins will not work as an amplifier. It cannot sound good. It cannot work !
regards Andrew T.
LM1875 PCB, Which To Use Paswa Chip Amps 238 1st November 2011 12:02 PM
Radio problem on noninverted GC??? 5150ed Chip Amps 2 17th August 2006 02:25 PM
DC offset problem from noninverted GC 5150ed Chip Amps 8 16th August 2006 04:39 PM
Low frequency cutoff calculation for Noninverted. 5150ed Chip Amps 19 11th August 2006 02:58 PM
Inverted gainclone with noninverted bridge mode akunec Chip Amps 0 20th October 2004 12:30 AM
Page generated in 0.11854 seconds (64.44% PHP - 35.56% MySQL) with 11 queries
