| Chip Amps Amplifiers based on integrated circuits |
Hello,
I'm putting together a system for a friend based around 2- FE103's in TQWT's. I plan to put together a couple of Audiosector Gainclone kits to drive them, and I would like to incorporate a high pass section (2nd order S-K bessel, fo around 85Hz- he has woofers) to protect and clean up the FE103's. I also read that it's beneficial to add a low pass filter to get rid of ultrasonics. And as far as grounding is concerned, would I be correct in assuming that the signal ground remains connected to the GC board as usual, and the gnd from the x-over goes to power gnd on the GC board (as indicated on the schem.), rather than signal gnd to x-over gnd to GC gnd? Details are provided with the schematic, and I would greatly appreciate your expert perusal to see whether or not I'm on the right track. - Great forum - TIA |
| Tapping master clock | habsrock93 | Digital Line Level | 10 | 8th November 2008 01:41 AM |
| Firewire or USB device for tapping I2s | lucpes | Digital Source | 1 | 8th November 2006 05:44 PM |
| Tapping a balanced connection | TheoM | Parts | 1 | 29th October 2004 02:51 AM |
| I2S tapping to M-audio Delta 44 | Kohjin Yamada | Digital Source | 0 | 9th July 2004 06:58 AM |
| drilling/tapping aluminum | elizard | Parts | 32 | 6th March 2004 06:18 AM |
| Page generated in 0.06770 seconds (63.00% PHP - 37.00% MySQL) with 11 queries |
