| Chip Amps Amplifiers based on integrated circuits |
I've built the tda2030a bridged circuit in the datasheet, and i was wondering if i can replace them with TDA2050a to make it sound louder? using a higher voltage of course that is
#2 |
ok i replaced them and it worked. What i'd like to know now is that if i should raise the voltage supply to get more power, i mean, with tda2030 the circuit uses 16+16v, should i use more with the tda2050's? what voltage should i use? the ic's max?
#3 |
Depends on the load impedance for 8 ohms you should be able to get the magic 100W with +/-22v supply but for a 4 ohm load you should use +/-18v to get 100W
I would not run them for long at that level because the To220 package does not have the area to get rid of the heat easily! One way around this is to build the "superbridge" in the TD2030A data sheet which has booster transistors that take some of the power dissipation. |
#4 |
Just found this application on the ST site (makers of the TDA2050)
Unfortunately it does not list that device but if you select TDA7265 which is approx 2 Tda2050's on the same chip but bigger area package you can get an idea of the dissipation problem http://www.st.com/stonline/products/...in/audpowl.htm Application needs java to run |
#5 |
i used the high power circuit in hte datasheet but replaced the tda2030 with tda2050 and i use 30v+0v+30v trans. max it up 130w..
| tda2030a Heatsink | hernanstafe | Chip Amps | 10 | 17th December 2007 12:47 PM |
| output stage of tda2030a | Hentai | Chip Amps | 0 | 18th May 2007 07:56 AM |
| TDA2050 parallel. HELP! | Matthewong | Chip Amps | 5 | 9th March 2006 03:47 AM |
| TDA2050 parallel. HELP! | Matthewong | Chip Amps | 11 | 13th February 2006 02:11 AM |
| Page generated in 0.07651 seconds (68.87% PHP - 31.13% MySQL) with 10 queries |
