| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I have set up a simple buffer circuit using two OPA134APs. I do not have null trimpots on it (didn't have any of the appropriate value in the parts bin), I have 770 uV on one output and 50uV on the other. What is the minimum acceptable dc offset voltage for use with my power amp (Adcom 545II)? I'm also using Panasonic 10uf bypass caps on the supply line right at the pins of the op amps, is this considered too big? |
#2 |
I am using LM833N pre for my LM4780 amp.
There is a linkwitz compensation on NFB line of LM833.. And my DC offset on preamp output is absolutely 0 mV. But on LM4780 i have +11mV on each channel.
Best regards, Ozgur |
#3 |
Electrons are yellow and more is better!
Less than 1 mV is very good. Nothing to worry about if this is from a line level buffer.
/Per-Anders (my first name) or P-A as my friends call me |
| What is acceptable DC offset on speaker terminals? | valterdaw | Car Audio | 3 | 3rd December 2007 09:01 PM |
| Offset voltage | borges | Multi-Way | 3 | 17th May 2006 07:38 AM |
| Offset Voltage Indicator? | Stocker | Solid State | 39 | 22nd April 2004 04:23 PM |
| DC Offset voltage | phil | Solid State | 3 | 23rd October 2001 06:37 AM |
| DC offset voltage? | harbin | Solid State | 2 | 13th June 2001 06:51 PM |
| Page generated in 0.10072 seconds (53.41% PHP - 46.59% MySQL) with 10 queries |
