Old 2nd March 2007, 11:08 PM   #1
mike_steinert's Avatar
Default Relay switched source selector
Apologies in advance if this topic has been covered, I did a search and couldn't find what I was looking for.
I'm attempting to build a source selector box using some mechanical Tyco DPDT relays I basically got for free on eBay. I've seen the schematic for the Darwin source selector. This is basically what I had come up with.
My question is whether or not it would be possible to reconfigure a circuit like this so that the audio signal doesn't go through the relay switch. I was thinking something like grounding out or shorting out the inputs that aren't selected, but I'm getting into design territory I'm not comfortable with (software is my trade).
Mike
Old 3rd March 2007, 03:17 AM   #2
Arx is offline Arx  Canada
Default Re: Relay switched source selector
Yeah, you would basicly be building a mixer, only with switches instead of pots. It would work, and probably sound fine, but probably not as good as just running it through the switches.
Sounds like a lot of extra design work, and probably more significant drops in sound quality to avoid something probably orders of magnitude below what any of us can hear.
Unless your relays really suck in amazing new ways.
-Nick
Old 3rd March 2007, 07:22 AM   #3
Default Re: Re: Relay switched source selector
I don't really know much about relays... They're mechanical power relays. The switch is rated at 240VDC... The contacts are HUGE. I suspect they're fine, even overkill for what I'm doing. I wouldn't expect to hear any sort of audible improvement by doing it some other way than running it through the switch, I was more just asking out of curiosity.
I think I'll probably just go ahead and build the thing how I originally planned.
Mike
input selector kit: relay: is this something oke ? then_dude Solid State 0 23rd June 2009 11:36 AM
Relay based source selector. Help needed! MASantos Chip Amps 9 8th August 2007 11:28 PM
Switched Pot Source Needed Trout Tubes / Valves 1 9th June 2006 01:42 PM
Digital relay switched log pot emulation audio .WAV's. Brian Guralnick Pass Labs 1 8th October 2003 05:39 PM
Relay - Selector Swich ruangrit Solid State 0 5th September 2003 04:58 AM
Page generated in 0.09945 seconds (59.46% PHP - 40.54% MySQL) with 10 queries
