| Chip Amps Amplifiers based on integrated circuits |
Hello I've just built my first gainclone using 2 LM3876 from 2 50W kits from Jaycar here in Australia. I have to say they sound great, but they seem to "bright" and I want more bass.
I have an additional LM3886 amp that I want to use to power a 10" subwoofer, in turn making a 2+1 system for my lounge room. I want to use Rod Elliott's Project 09 (24 dB/Octave 2-WAY Linkwitz-Riley Electronic Crossover) as my pre-amp filtering, which results in mid-high pass powering the 2 satellites and the low pass powering the sub. My question is how can I mix the left and right low pass channels into the sub amplifier? Is it as easy as joining the two outputs from the low pass section in Project 09? Cheers. |
#2 |
You can peek into Projects 48 or 71 to see how to 'sum' the input before the low pass filter.
For your satellites, you'll need one high pass for the left channel and one for the right channel. The subwoofer mono sum can be derived directly from the stereo input, no need to waste the space and money for two identical low passes. IC U1A in P48 (or P71) shows how to do it. Then connect one of P09's low passes behind such a summing buffer. You might also want to read Siegfried Linkwitz's original articles, some of them also show how to design a 2.1 crossover. Cheers. |
#3 |
Greetings, Usually I wouldn't mention a particular company, but this info might be of help to you. I just completed a similar arrangement and for the crossover used a kit from Marchand electronics (New York USA). I just stumbled on them by accident. The kit was pretty cheap for a pair of xovers (about $65US) and the quality was excellent - glass boards etc. It is a 24 db high and low, the freq can be adjused by changing 4 identical resistors on a dip header. They include one set at the freq of your choice. Mine came with Burr Brown ICs. Very quiet and works super.
Good listening Bruce |
| Linkwitz-Riley Crossover questions | MBrej | Solid State | 2 | 15th January 2009 12:19 PM |
| A Challenge to Linkwitz-Riley ? | jackinnj | Multi-Way | 17 | 14th March 2006 11:50 PM |
| Linkwitz-Riley Cross over question | rs1026 | Chip Amps | 2 | 27th August 2004 09:15 PM |
| linkwitz-riley crossover | arthur | Solid State | 0 | 28th April 2003 10:26 AM |
| Linkwitz-Riley 24dB/octave Phase Coherent Crossover | djdan | Solid State | 30 | 25th September 2002 10:32 PM |
| Page generated in 0.08678 seconds (67.58% PHP - 32.42% MySQL) with 10 queries |
