Old 28th February 2007, 02:17 PM   #1
louischia's Avatar
Default No microcontroller for PGA2310?
Can a simple volume controller with PGA2310 do without programming a microcontroller?
I know nuts about programming but would like to build a volume controller to go with my Class-A Amp.
Can anyone provide me with a simple schematic of a 2-channel volume controller using a PGA2310? Hopefully no PICs or other chips that need programming needed. 3 push-buttons to control it; volume up, volume down and mute.
Thanks!
-Louis
new kid on the board!
Old 28th February 2007, 02:32 PM   #2
I_Forgot's Avatar
Have you looked at the data sheet?
A 3 wire controller is required to control the PGA2310.
You need a microcontroller.
Dallas Semiconductor makes some electronic pots that have built in controllers so all you need to connect are up and down buttons.
I_F
Old 28th February 2007, 02:32 PM   #3
hacknet is offline hacknet  Singapore
ive been trying to do it with logic updown sync counters into a multiplexer but i havent serious worked on it.
Old 28th February 2007, 03:48 PM   #4
jackinnj's Avatar
yes, you can control it with a dual 8 bit DAC, a CMOS oscillator and a little bit of CMOS logic. you use a potentiometer and VCC as the input to the DAC, just make sure that VCC is quiet.
Old 28th February 2007, 03:51 PM   #5
I_Forgot's Avatar
You could probably do it with a rack full of vacuum tubes, too...
I_F
Old 2nd March 2007, 07:48 AM   #6
If you want to control volume without an mcu, then consider DS1802 and DS1666
or if your could solder a 48 pin TSSOP chip look at MAX5406
Old 2nd March 2007, 08:57 AM   #7
Have u read the thread
lightspeed attenuator ....in solid state
May be u should go for this. Simple and better.
Gajanan
Old 4th March 2007, 01:56 AM   #8
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Yup, there's even leds output to indicate volume and balance
Good luck !
Old 4th March 2007, 04:20 PM   #9
jaycee is offline jaycee  United Kingdom
The amount of standard 7400 series logic you'd need to drive a PGA2310 makes it unfeasible. You;d have to have two 8 bit counters supporting increment and decrement, and some shift registers, and a clock.
I belive there was someone on DIYAudio that had made a simple kit that basically had an 8 pin PIC which connected to a potentiometer. This then drove a PGA2310/11. Try searching here. Thing is, a microcontroller is pretty much unavoidable.
edit: The kit i was thinking of was the Twisted Pear Kookaburra. Hardly simple, but it'll do the job
Old 4th March 2007, 04:41 PM   #10
audiosteve's Avatar
You could probably do it with an FPGA. Lattice makes a few that have built in FLASH so the program self loads. They behave more like a CPLD. You may be abe to use a CPLD as well but the per gate cost on those tends to be much higher compared to FPGA's. Lattice aso has a free version of their software that you can use to develop the code. The programming cable, however, is not free. And the parts, through distribution, would also cost more than a small micro. And it is still a programming job. Instead of using C or assembler you would use Verilog, VHDL or ABEL.
So I am not sure if this is a cost effective solution, but it is a possible solution. In any case you would probably have similar expense and hurdles to deal with when using a micro. For a one off application the cost of the silicon itself is the least of your worries. BTW, I have no affiliation with Lattice. I just happen to think they are making some great CPLD's and some fairly innovative FPGA's these days. I've used these parts.
If you are a serious hobbyist, programmable logic opens up all kinds of other design doors for you. It wouldn't hurt to get your arms around this technology as a good learning exercise.
Microcontroller Help imix500 Parts 8 3rd September 2008 02:49 AM
help with microcontroller sss Everything Else 2 31st July 2008 04:30 PM
Krell microcontroller help serraniruben Digital Source 0 2nd May 2008 10:28 PM
Protecting a microcontroller rtarbell Parts 10 11th January 2008 01:23 AM
FLAC on microcontroller gene_klein Digital Source 4 1st December 2007 02:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
