| Chip Amps Amplifiers based on integrated circuits |
I purchased the following transformer for my audiosector gainclone:
Plitron 067014011, 18V @ 6.25 amps, 225VA, 2x115 VAC, F:50 I will be wiring this for 230v mains and couldn't find any info at the plitron site. Does anyone have a wiring diagram or a simple explanation on how to do this. Sorry for the noob question. Thanks! |
#2 |
Did it Himself
There should be a label on the transformer. The two 115v primaries are wired in series, but you must get them in the right order. If you look on the label the starts (or maybe the finishes) of the secondary windings is denoted by a dot. You must wire finish1-start2 between the windings.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
#4 |
#5 |
yep. that's the one. i bought it when visiting new york in december.
there's got to be someone using a plitron with 230v... |
#6 |
Did it Himself
At a guess, the brown wire is live and the blue is neutral. The brown will have an associated 'partner wire' that is right next to it - the other end of the winding. The blue will have a similar wire. These two wires should be joined together for 230v operation.
#7 |
that pic showing wht and brn next to each other indicates that these two wires should be connected and the other two primaries become live and neutral. Just power it up through a mains light bulb and even if we have got it wrong there will be no damage and no fuse blowing and no overheating and no tears.
regards Andrew T. |
#8 |
hi andrewt,
thanks for that. i just found this page: http://www.plitron.com/standard_schematics.asp it looks like you were right to tie together white and brown. cheers! larry |
| ok, power supply question, 230v - 117v conversion | aardvarkash10 | Tubes / Valves | 6 | 21st July 2009 01:11 PM |
| Power Transformer 110/230V Windings Question | LinuksGuru | Tubes / Valves | 4 | 13th July 2009 10:26 PM |
| Question about autotransformer ( 230V to 115V ) | Rodeodave | Power Supplies | 5 | 4th June 2007 01:11 PM |
| Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers | Eva | Swap Meet | 1 | 28th July 2005 03:00 PM |
| PS question- Need to get 20V AC from 60V AC - w/o Trafo | lgreen | Pass Labs | 9 | 2nd January 2004 10:31 AM |
| Page generated in 0.11722 seconds (62.14% PHP - 37.86% MySQL) with 10 queries |
