I want to start small, have a question about a toroid
Old 27th February 2007, 07:20 PM   #1
beerman is offline beerman  United States
Default I want to start small, have a question about a toroid
I decided I want to build a small chip amp for my PC using a single LM1876.
This unit from digikey is called a "mini". It is a 50va with 12v secondaries.
Will that suffice for a small 15w per channel stereo amplifier?
Got Bass?
Old 27th February 2007, 09:07 PM   #2
bremen nacht is offline bremen nacht  Europe
Just about, a bit on the small side but probably a lot better than most of the PC systems advertised as 60W or more...
Old 28th February 2007, 02:15 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Yes,with something like the LM1875.
Old 28th February 2007, 03:55 AM   #4
If I recall, the 1876 is two 1875s in a single chip?
Got Bass?
Old 28th February 2007, 04:26 AM   #5
twitchie is offline twitchie  Canada
I think you'd be better off with a chia-yu xformer from apexjr for 12.50
http://www.apexjr.com/miscellaneous.html#Toroids
12V will be on the low side
Old 28th February 2007, 06:33 AM   #6
I'll admit to being a newbie on this subject.
I'm trying to stay "safe". I will want to run 4ohm drivers with this amplifier at one point or another.
Correct me if I'm wrong: if the drivers are low impedance, shouldn't the PSU send lower voltage to the chip? (I don't remember the reason, I'm no engineer, but I do remember reading it somewhere.)
But that is a decent deal.
Got Bass?
Old 28th February 2007, 10:38 AM   #7
Yes, that's right.
The required voltage into a given impedance speaker for a given power is V = sqrt(PR) where sqrt is 'square root'. So you need less V into 4 compared to 8. You could keep the supply high, but you'd increase the power dissipated in the amp chip.
So for 15W in 4 ohm you need 7.5V RMS = 11V peak. Add a few (or look at the data sheet) volts for losses in the amp, so it looks like 15V rails will do the job. A 12V transformer will give about 15V after rectification, so there you go.
I want to start small, have a question about a toroidHide this!Advertise here!
WTB: small toroid 2x15V 50VA AR2 Swap Meet 0 3rd December 2006 04:17 PM
Does 300VA toroid need soft start circuit? orthoefer Power Supplies 26 18th May 2006 11:41 AM
Toroid soft start officeboy Power Supplies 21 27th April 2005 02:34 AM
Start of winding in toroid matters? ftjandra Chip Amps 1 1st July 2004 08:13 AM
