Old 26th February 2007, 11:01 PM   #1
Colin is offline Colin  United Kingdom
Default Recommended UK transformer for 3875 chipamp?
The time has come at last to build the LM3875 chipamp as I've had Peter's kit long enough to start feeling guilty about it.
The Plitron transformers are prohibitively expensive to buy from here in the UK (postage is more than the transformer), so what other transformers would UK builders recommend?
Old 27th February 2007, 03:08 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
http://www.madaboutsound.com/prod_det.asp?product_id=33
/U.
Old 27th February 2007, 11:11 AM   #3
Thanks but I think he's discontinued those.
Old 27th February 2007, 11:29 AM   #4
http://uk.farnell.com/jsp/search2/br...RY%7c1#results
Minimum order of £20, but the delivery is free... and a single big transformer / two smaller ones will very likely be over £20 anyway
I got two 120VA dual 25vac secondaries, dual mono style regulated supplies, 'Multicomp' ones and they work great. These rectified to about 36-37vdc, so you'll probably have to be a bit careful if you're going with an unregulated supply.
Old 28th February 2007, 02:58 PM   #5
CarlosT is offline CarlosT  United States
Are these guys anywhere near you? The little encapsulated Avels powering my LM3875 are just peachy and made in England...
http://www.avellindberg.co.uk/
Old 28th February 2007, 04:20 PM   #6
Aha, that looks more like it. I tried hunting online for Holden and Fisher who used to make the very solid, well-built toroids which appeared in early, Olive-case Naim gear, but either they are no more or are hiding. The Avels have a good reputation, though, so thanks for drawing that to my attention.
Old 1st March 2007, 08:02 PM   #7
AndrewT is online now AndrewT  Scotland
Rapidonline were discounting their non ROHS stock, but I fear they are very depleted now. They have had a -30% offer and a -10% offer just recently. The Non ROHS are more like -50% to -75% on what are very competitive prices.
regards Andrew T.
Recommended output valves for this transformer Hi-Q Tubes / Valves 3 8th November 2010 12:08 AM
Grounding chipamp 3875 marcus7601 Chip Amps 10 10th April 2009 10:33 PM
FS chipamp 3386, 3875, 1 enclosure wendell Swap Meet 4 15th June 2008 03:06 PM
Preventing a 3875 chipamp from blowing tweeters bcdzt5 Chip Amps 8 6th February 2008 07:23 PM
Chipamp.com pcb with linkwitz 3875 design akunec Chip Amps 3 7th June 2005 07:06 PM
Page generated in 0.10521 seconds (67.83% PHP - 32.17% MySQL) with 10 queries
