LM3886 humming problem
Old 25th February 2007, 03:51 PM   #1
Niila is offline Niila  Finland
Send a message via MSN to Niila
Default LM3886 humming problem
Hello!
Suprise, i have a grounding problem. Im using BrianGt's LM3886 boards . So far, i have only assembled one channel of two monoblocks. The humming is not really a problem when listening music, but i want to know why it does that.
I use 5-lead xlr connectors to connect blocks to my PS.
Powergrounds go to the PS of cource, and channel grounds goes to the star point..you know what i mean Mains ground is also connected to the same point. Im usin plastic enclosures in both monoblocks and PS.
Signal ground from the rca connector goes through the pot to the pcb.
Small heatsink that i have inside the enclosure, is not grounded, as it isnt conncted to the circuit anyhow. Any way i did try to ground it, but i didnt make any difference.
For some reason, the humming sound amplifies a little bit when i touch the heatsink. The hum attenuates when i touch rca ground The chip is insulated, so there should be no problem here?
I will post pictures later
edit: oh, and im using 4ohm speaker for testing..i know 8 would be better as i use +-35V rails but...
Old 25th February 2007, 08:19 PM   #2
How does the mains ground (safety earth) get to the audio ground?
How have you connected these pins?
Do these connect anywhere?
The only risks to a user are from the RCA or the speaker terminal becoming live and the risk of sending a live feed back down an interconnect to an ancilliary. Do you have any other metal or conductive parts that come through the enclosures?
Do ensure that the mains fuse will blow if any of these become live.
bad decision.
regards Andrew T.
Old 26th February 2007, 04:40 PM   #3
Hello and thanks for answering.
All grounds (audio and mains) except the "power grounds" goes to the same star point. This includes channel grounds from the monoblocks.
Xlr pins are connected in fololowing order, from eleven o'clock to one o'clock: -PG,-V,CG,+V,+PG. As only DC voltages are carried in the leads, no humming should be produced here.
No live should get to the amp. Theres always the risk. Potentiometer is half outside, but i use a plastic knob. Check out the pics in the gallery.
I now have 8ohm speakers. It didnt make any difference.
Old 1st March 2007, 07:20 AM   #4
Xlr pins are connected ....... -PG,-V,CG,+V,+PG. As only DC voltages are carried in the leads, no humming should be produced here.
What is CG connected to inside the mains PSU box? Is CG=0v?
What is CG connected to inside the amplifier box? Is there a connection from CG to TWO inputs leads?
regards Andrew T.
Old 1st March 2007, 12:52 PM   #5
CG (Channel ground) is the main ground from the pcb. Input signal gound, output ground and both power grounds are connected to this point on the pcb. CG is the only ground from the amplifier which goes to the star point. So ground loop is not possible here. Mains ground also goes to this point.
Old 1st March 2007, 08:34 PM   #6
This says it is very likely you will end up with an earth loop that causes hum and possibly buzz as well.
regards Andrew T.
Old 1st March 2007, 09:19 PM   #7
How come, if the CG is the ONLY ground lead connected to the amp? Power grounds are NOT connected to the CG on the PSU end, so its not really a loop. Rather Y or U.
Old 1st March 2007, 09:29 PM   #8
what does this mean?
regards Andrew T.
Old 2nd March 2007, 01:52 PM   #9
That mains ground or safety ground, (from the wall) is connected to the star-point.
Groundings
Old 2nd March 2007, 02:03 PM   #10
I think you are confirming that the audio ground is connected to the safety ground which in turn is connected to the house earth ring/star back to distribution board.
You have also confirmed that audio ground is connected to the input terminal ground/return.
If you fit two or more inputs into this system you are guaranteed to create an earth loop.
If you connect just one input and that source is also connected to earth then again you have created an earth loop.
What you are describing is very likely to incorporate an earth loop, no matter how many times you say it can't. You have to do something to break the loop/s.
That linked layout will create a hum loop. It also omits the 0v from the PSU and omits the safety earth. That alone creates a hum loop. Then connect a two channel source to the two input RCAs and you have three hum loops. I do not recommend that you follow that layout.
regards Andrew T.
LM3886 humming problemHide this!Advertise here!
Subwoofer Humming problem Vandergraaff27 Subwoofers 71 31st January 2015 02:25 PM
Guitar Pre amp humming problem ali_moinuddin Pass Labs 1 6th July 2009 05:31 PM
Guitar Pre amp humming problem ali_moinuddin Pass Labs 0 6th July 2009 05:17 PM
Humming Noise, Problem? MorePower7701 Solid State 2 26th December 2007 06:49 AM
Weird Humming problem diegot Chip Amps 18 2nd November 2006 10:42 PM
Copyright ©1999-2017 diyAudio
