LM3886 Heatsink size?
Old 25th February 2007, 11:21 AM   #11
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
You need to take a few things into account.
Andrew has mentioned the first thing, which is that your rail voltages are too high for a 4 ohm load. You should reference the chip manufacturer spec sheet which will give you all the info you need regarding voltages, load, heatsink requirements.
Also, it will depend on your speakers, as a nominal 4 ohm load will actually dip lower than 4 ohms to varying degree depending on the speakers.
Another factor is how loud you're listening to them.
V
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 25th February 2007, 03:48 PM   #12
henkel is offline henkel  Malaysia
Thanks guys,
You are right about not refering to the spec of the LM chip. I had refered to friends whom have built the LM3886, and both recomended 24V tranny for 4ohms speaker.
I'll re-check the voltage rails. Thanks.
Old 9th March 2007, 08:39 AM   #13
Hi guys,
I have solved the heat problem with my LM3886, by changing to larger heatsinks, measuring 8 x 3 1/2 inches.
The voltage rail is still high at 36.5V, but the amp is not shutting down now. The heatsinks do run hot but still touchable, without the "burn" sensation.
The LM3886 sound really wonderfull now, and after listening to them for 2 long nights, I can now see why my friend, almost gave up his high end audiophile for the LM3886.
Once again, thanks to all who assisted, especially Andrew T.
Old 4th May 2007, 05:49 AM   #14
melbsp is offline melbsp  United States
Default LM3886 hot even w/o load/speaker
Hello,
I've read through your comments. It looks like I have the problem that Andrew mentioned where if you don't have your speaker connected and the heatsink still gets hot, then your amp could be oscillating or spiking.
I'm sure it isn't spiking. I'm using DC voltage to bias the op-amp. +/-12 V powersupply & 1.3A. I have the amp set up as a voltage follower. The input is my ipod which as a max of 1.5 Vpeak (I measured with an oscope, but had no luck finding speaks on web for ipod output).
Since the amp is set up as a "voltage follower"/"current buffer", the output voltage is at most 1.5Vpeak at any one time. I do not have an external heat sink applied, but only after 1.5 or 2 minutes, the lm3886, starts to get too hot and you can hear the poor performance on the output.
My speaker is 8 ohms. It has been over 5 years since I took a detailed class on op-amp design. Although oscillation sounds familar, I don't remember exactly what to look for. Could this really be the problem though or is it something else. I have read the datasheet over and over, so I apologize if I missed something that is obvious to others.
~mel
Old 4th May 2007, 09:21 AM   #15
follower = gain of one.
What does the datasheet say about minimum gain?
regards Andrew T.
Old 5th May 2007, 11:52 PM   #16
Default minimum gain
Thanks for the comment Andrew..
The datasheet shows examples of various applications and how to calculate their gain, but it doesn't limit the gain ... as far as I saw (in the general spec data).
I rewired the circuit. It is now set up as an inverting op-amp with a gain of -6.5 (about) |A| = Rf/Rin = (93.2k/14.4k). Rin is in series with Vin and then to the inverting input of the op-amp. Rf is from the inverting input to the output of the op-amp.
Really Rf is a pot so the gain can go as low as 0. The noninverting side is grounded. Anyway, with the Gain at 6.5 and no speaker/load, it no longer gets extrememly hot. only a tiny bit warm.
If I do set the gain to be -1 (Rf=Rin= 14.4k), then w/o the speaker the op-amp does get really hot. Why would they design an op-amp to limit the minimal gain for your design? I'd like to be able to turn the volume all the way down to low some times. I could do this using the IPOD, but it would be nice to have one knob do everything.
If I have to, then I guess I can just use the mute button and limit my minimal gain and/or use ipod controls, but I"ll order some heat sinks and see if that helps as well. I'll read over the specs in more detail later, but on page 20. It is just showing basic equations for example circuit designs they have. I've set it up (with having a max gain of 6.5) to make sure the power supply can supply enough voltage and current at the output.
Also, I'm not wanting to make any power supplies right now. but if I were to take two old laptop power supplies (both are about 19V & 4 A) & hook them up as my dc bias power for the op-amps(instead of the two dc power suplpies I have now 12V & 1.3A), will the op-amp (741 & the LM3886 only draw enough current as what they need?).
Ohms law has to apply across the device right? So if it were 2 resistors in series across the supply, then it would be straight forward. I'd assume the voltage is set at 19V and the current is 19V/(R1+R2). But does it work a similar way for op-amp in general or do they always sink whatever current is not being used from the other components (that is still left in the power supply)?
Perhaps this is a simple question but we never went over power supplies much at Chico State in my undergrad anyway. Thanks bunches! :-)
Old 6th May 2007, 01:23 AM   #17
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
Hi melbsp,
Quote from datasheet:
"LAYOUT, GROUND LOOPS AND STABILITY
The LM3886 is designed to be stable when operated at a
closed-loop gain of 10 or greater, but as with any other
high-current amplifier, the LM3886 can be made to oscillate
under certain conditions. These usually involve printed circuit
board layout or output/input coupling."
regards
Greg Erskine
Old 6th May 2007, 07:18 AM   #18
Default thanks Greg
Thanks Greg,
I was hoping that wasn't the case, but on the other hand, it will sound great when it is at the higher levels, so I'll just have to redesign and hear what it sounds like. Do you have any tips for power supplies that produce enough current and voltage to run LM3886 to get the most out of a 60W 8 ohm speaker.
V = sqrt(PR) = 22 volts
I = sqrt(P/R) 2.74A (actually about 6A needed from power supply for everythign)
I'm assuming if I need 2.74A to go through my resistor, then the power supply has to supply at least that much. You can't get something for nothing, right ... or is there some magic going on with the op-amp?
Also I'll be biasing 2 LM3886 & at least four 741 op-amps, so I'll need probably a total of about 6A. Assuming no "magic" happens.
Smiles ~ Melody
Old 6th May 2007, 07:18 AM   #19
Default Gain of 18
Hi Greg (and Andrew),
so I rewired the circuit with a gain of 18. It now is running much longer with only a little heat sink on it. I guess I'll just use my ipod to control the volume, so that way I don't have to have a huge hink sink. I was trying to design it to use the knob on the device, but that is only because I'm a TA for a lab and that is what the student are required to do. I'll let them know that they can increase the volume using the knob of a LM3886 but only if the make the gain increase from 10.
Thanks for spotting that in the datasheet Greg. I wish they would make the important data like that in the table (quick reference), but teaches me that you really have to read all the information even if it is just on the applications.
Anyway, thanks bunches. It sounds loud enough for my "ballet studio" in my garage (currently only one LM3886 connected though). I'll try it with two later and if I need more power from power supplies, I'll message you all for advice.
Thanks again!
Melody
Old 6th May 2007, 09:37 AM   #20
Default Re: thanks Greg
Originally posted by melbsp
Thanks Greg,
Smiles ~ Melody
transformer + rectifier + smoothing = PSU for a chipamp.
For reliable maximum into an 8ohm speaker use a 25Vac to 28Vac transformer. For two channels try to find a 4 secondary toroid. One pair of secondaries for each amplifier.
100VA to 150VA is adequate for one channel.
P=V^2 / R = I^2 * R.
which is the required answer? I. Then use I= SQRT[P/R]. But this is Iac.
Ipk= SQRT[2*P/R].
Minimum resistance of an 8ohm speaker is about 6r0 but can be less. When feeding a crossover to multiple speakers the minimum impedance can be even lower. If it is a 4 to 8ohm speaker then Re and minimum impedance can be as low as 3r0. These low impedance bass/mid drivers have become very popular.
Now calculate Ipk for 6r0.
Ipk=sqrt[2*60/6]=4.47Apk and for a 4 to 8ohm speaker about double this i.e. 9A.
Oh!!
That's more than the guaranteed maximum for most of the chipamps on the market.
regards Andrew T.
LM3886 Heatsink size?Hide this!Advertise here!
Mini-Aleph Heatsink size ??? patoff Pass Labs 3 4th July 2007 03:31 PM
Heatsink size ??? djdamix Solid State 12 14th March 2005 11:20 PM
minimum heatsink size for lm3875 mateo88 Chip Amps 2 7th June 2004 06:30 PM
heatsink size theChris Chip Amps 5 15th January 2004 08:32 PM
What size heatsink is needed for Rod's 3A amp? kec Solid State 5 26th February 2002 02:13 AM
Copyright ©1999-2017 diyAudio
