How does this look for a amp chassis? - diyAudio
Old 20th February 2007, 05:47 PM   #1
JCoffey is offline JCoffey  United States
Default How does this look for a amp chassis?
The price is right at $20
http://www.newegg.com/Product/Produc...82E16835185040
I doubt with its height it would be able to fit a Torroid, but it looks like thers sufficient cooling. But Im still a noob with GCs.
Old 20th February 2007, 06:51 PM   #2
ianpengelly's Avatar
It would be tight, but pretty awesome if you could pull it off!
Old 20th February 2007, 08:00 PM   #3
beerman is offline beerman  United States
Whoa, That fits in a 5.25" bay?
Can a chipamp run off +/-12v? No need for the Toroid then. Just the biggest ATX power supply you can find.
Got Bass?
Old 20th February 2007, 08:25 PM   #4
azira is offline azira  United States
A better bet would be an external power supply to feed this thing. ATX power supplies give high current at +12V but very little current at -12V. AFAIK, it's difficult to find more than 1A @ -12V in ATX power supplies because most components on a mobo don't need the -12V.
Nice looking case though, makes me want to get one or three...
Danny
Old 20th February 2007, 08:46 PM   #5
THey also for about $3 more have a Silverstone brand HDD heatsink enclosure that looks MUCH nicer, in both black and silver.
And it wont be going in a PC, and wouldnt be using a ATX power supply. I'd probably have to come up with a different enclosire for that...........
Old 20th February 2007, 09:40 PM   #6
dvarner is offline dvarner  United States
How about two of them back to back with the toroid inside?
The toroids spoken about often here are around 2.5" tall.
Might need a spacer between the two clamshells.
DV
Old 20th February 2007, 11:46 PM   #7
lgreen is offline lgreen  United States
lgreen's Avatar
Default looks nice
Hey, those are neat and should work fine if you can squeeze a chipamp into them. good to see some new cases like that, thanks for the post.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 21st February 2007, 03:35 AM   #8
I LOVE the first one!!!! A pair of P2P LM3886 chipamps would be ideal. My only concern would be enough heat sink. But you know what? The thing would still look good with a fan right on top. Been there, done that.
As azira said, consider building a separate enclosure for the power supply.
I've built a couple where the power supply is separate and "out of sight". No probs.
Edit: And I also thank you for the post!
Poor stereo mix? Switch to mono! Perfect.
Old 21st February 2007, 02:45 PM   #9
Honestly I really dont think cooling would be an issue. I used to have a commercial amp that ran dual 3886's and they were both on one heat sink the size of a Pentium 2 heatsink, and it NEVER got too hot. Im planning on using the first one after reading the reviews on the Silverstones cooling fan being waaaaay too loud, but if you really wanted a fan, you can always use a resistor to slow the fan down. Either way, both of them look a ton better than the heatsink enclosures that Parts express sells. I could probably use on eof those for the PS box down on the floor or something........
Old 21st February 2007, 03:31 PM   #10
theAnonymous1's Avatar
The heatsink boxes from PE can look good if you put a bit of effort into it.
5E3 chassis Colinsky Everything Else 0 23rd July 2008 11:10 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
WTB: 2U chassis DcibeL Swap Meet 14 16th December 2006 02:06 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
Copyright Đ1999-2017 diyAudio
