Old 20th February 2007, 01:12 AM   #1
impsick is offline impsick  United States
impsick's Avatar
Default opamp swap
I hate to post a whole new thread for this but my searching has come up empty. i know there is all kinds if info online but none regarding my two choices at hand. maybe cause its not compatible, i dont know, so i ask diyaudio...
ok so i got this mic-pre with NE5534 opamps in it and i was wondering if i can put some AD744 in its place just to see the difference? is this possible?
thanks, Omar
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 20th February 2007, 02:20 AM   #2
gootee is offline gootee  United States
I went to http://www.google.com and found the NE5534 datasheet "immediately":
http://www.onsemi.com/pub/Collateral/NE5534-D.PDF
And the AD744 datasheet is available from Analog Devices' website:
http://www.analog.com/UploadedFiles/...eets/AD744.pdf
You can right-click on the links and select "Save As", to save copies to your hard drive.
Good luck.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
Old 20th February 2007, 02:42 AM   #3
impsick's Avatar
ya, i have both data sheets, im just being lazy. see the pins seem to be in the same spots im just confused on the whole balance and null thing. im a noob. but thanks man, i guess i'll try to be productive and pretend to understand all that data on the sheets. ha
god dang 20+ views and no "yes" or "no"? i know you all know the answer and are just laughing seeing how long you could drag this out before i snap. there, i snapped.
Old 20th February 2007, 09:10 PM   #4
Op amp balance and null circuits are rarely used in audio. They are only useful if you are using DC coupling with no DC blocking capacitors.
IMHO, the AD744 would be a poor choice for a microphone preamp. It would probably work, but it would be noisy. Try a good low noise bipolar input device like the AD797, OPA227/228, LT1028, LT1128, or LT1115 instead.
Old 20th February 2007, 09:19 PM   #5
impsick's Avatar
nice! thanks for your reply, exactly what i needed to hear.
OpAmp Swap? edge4syn Tubes / Valves 8 9th February 2009 01:30 PM
opamp v4580m swap Faitho Digital Source 2 16th March 2008 05:13 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
swap CS4390 guytou Digital Source 0 18th August 2005 10:35 AM
want to swap some tubes briand Swap Meet 1 9th June 2003 12:59 AM
Page generated in 0.10585 seconds (68.48% PHP - 31.52% MySQL) with 10 queries
