Old 19th February 2007, 12:12 PM   #1
Default Another grounding issue
I have done a lot of searching regarding the "proper" way to ground a gainclone-kit (3875) from Audiosector. However, i still didnt get a definitive answer. I use one transformer CT and one diode bridge.
Grounding points:
Rectifier (1)
Stereo volume pot (2)
RCA in (not insulated from chassi) (2)
amp-boards (2)
AC Safety earth (1)
How does the grounding-procedure change if connected to AC-outlet with no safety earth? (Even possible?)
Can someone help guy that eagerly tries to learn?
Old 19th February 2007, 10:20 PM   #2
AndrewT is online now AndrewT  Scotland
Default Re: Another grounding issue
Grounding points:
Rectifier (1)
AC Safety earth (1)
with a single rectifier and centre tapped transformer, none of the four rectifier connections go to ground.
The RCA must be isolated from the chassis.
The metal chassis must be connected to safety earth.
regards Andrew T.
Old 20th February 2007, 07:47 AM   #3
Ok, RCA in is now insulated.
So, if i get this correctly a star groundpoint is made on the chassie itself. One wire from each channel board (CHG) is connected here and from the star ground a wire to AC ground?
Does the volume pot need to be grounded and if so, also to the star ground?
Old 20th February 2007, 03:34 PM   #4
If you connect both channels to a common ground, then as soon as you connect a second input cable you will create a hum loop.
regards Andrew T.
Dual-mono chipamp (3886) problem - possible grounding issue phresh Chip Amps 31 29th February 2008 03:50 PM
1876 hum - grounding issue? derMichi Chip Amps 2 3rd May 2006 08:07 AM
Please help.... Grounding issue, and 60 Hz hum PaulHilgeman Parts 25 27th November 2004 10:30 PM
Another PS and grounding issue sam9 Solid State 4 13th September 2003 12:07 AM
Page generated in 0.07352 seconds (69.91% PHP - 30.09% MySQL) with 10 queries
