Old 18th February 2007, 09:08 PM   #1
Default problems with subwoofer amp!
As some of you know i'm building a subwoofer and i was going to use a bridged tda2030a amp to power it. I bought a 10" sub recently and it comes to be that i don't have near enough power to make it work properly. That amp delivers about 34W max and i need like 100W. I've been searching the forum for a 100W amp and i found some but they don't have the pcb designed, only the schematic. I'd like to know if someone has the schematics AND THE PCB for a 100 - 150 W amp, with good quality sound.
PD: I'm not sure if i should use an AB or D class amp either, HELP!!
Thanks everyone!
Old 19th February 2007, 12:42 AM   #2
Default Try 41hz.com...
One amp I think could work well in your application is the Amp5 kit. http://www.41hz.com/main.aspx?pageID=120 While I no personal experience with this kit (or any 41hz.com kits), I've heard many good reviews about them.
Old 19th February 2007, 12:55 AM   #3
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Where will you use it? I use AMP9 in my car (2x200W at 2 ohms when parallelled! Or 1x 400W at 1 ohms?)
I don't know AMP5, but read a lot of good things about it....
For subs class D (T) is excellent, can't get better control and power for the money...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 19th February 2007, 07:19 AM   #4
mateo88 is offline mateo88  United States
Buy a kit from chipamp.com. If you have a 4 ohm sub woofer, you can parallel two chips to get 100 watts.
I have no idea how to help you if it's for a car, though.
Old 19th February 2007, 04:53 PM   #5
hey guys thanks for the replies. It's not for a car it's for home use, and i can't buy one of those kits, i'm from Argentina, sending it here would be ridicously expensive. I need the schematics and pcb to actually BUILD it. The speaker is 4 ohm by the way!!
Old 19th February 2007, 06:15 PM   #6
Minion is offline Minion  Canada
Well if you want to actually build it then Take the Schematic and use a PCB design program and design your own PCB and then you have your own PCB.....
If you can read a schematic you can design a PCB and most Chips amps are very simple so there shouldn"t be a Problem makeing your own...
Ive done it......
Old 19th February 2007, 06:29 PM   #7
FastEddy's Avatar
I just finished a very nice sounding sub using an NX-150 power amp module from aussieamplifiers.com (a ready made module = just add DC power and a chassis), installed in a stand alone box ... connected it to a sealed 3.1 cubic foot enclosure with a 12" Pyle Driver (8 ohms, nominal) as used in car systems. I like having an automotive type bass woofer as they last a long time in home stereo environment, have nice tight, heavy duty frames and thicker, yet more flexable diaphram mounting and a large coil & huge magnet = play it load and it still lasts and lasts.
I had to "pad down" the gain on the Aussie Amp somewhat to get it into balance with the rest of the system (@ 150 watts the sound pressure level is enough to rattle the windows) . The sub rolls off around 5 Htz and I set the active low pass on the pre-amp to 150 Hz = no internal passive crossover in the sub = simple, I think it sound great and so does my wife.
You could build your own chip amp from kit or from scratch from a circuit diagram and up ... but I prefer amp modules as the time consumed on the bench is seldom equal to the level of improved quality from a good sounding module, chip amp, power MOSFet amp, tube amp or whatever = the module makers are doing some really high tech, high quality work that is seldom beatable with a soldering iron ... IMOP
Old 20th February 2007, 06:41 AM   #8
http://audiosector.com/lm4780.shtml
Subwoofer problems pilchardman101 Car Audio 8 3rd May 2008 03:17 PM
anybody facing stability problems with LM3886 BA100 with 8 ohm subwoofer? rhythmdiy Chip Amps 1 31st October 2007 06:04 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Infinity BU1 amplified subwoofer. problems. pat allen Solid State 0 30th December 2004 02:42 PM
Subwoofer (Sealed) Problems Duo Subwoofers 7 18th November 2002 03:18 AM
Page generated in 0.10102 seconds (78.60% PHP - 21.40% MySQL) with 10 queries
