Oscillating with a resistive dummy load
Old 16th February 2007, 12:30 AM   #21
billbo is offline billbo  Australia
Default oscillation issue
Try using an 8ohm speakers. I had the same problem only if I ran the amp into an 4 ohm load. It will work fine into 8 so I left it with 8 ohm speakers. It could be a zobel problem. Or your power supply is too high for 4 ohm loads.
Old 16th February 2007, 10:35 AM   #22
markiemrboo is offline markiemrboo  United Kingdom
Default Re: oscillation issue
There's no chance I would risk doing what you're doing... even if I did just happen to have speakers which I knew didn't go below 8 ohms, but I got it sorted anyway (see a few posts back) :P
Oscillating with a resistive dummy loadHide this!Advertise here!
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Parafeed with resistive load mashaffer Tubes / Valves 9 16th September 2005 07:19 PM
