Old 7th February 2007, 02:15 PM   #1
eris is offline eris  United States
Send a message via AIM to eris
Default Hi Power Chip Amp Anyone?
Does anyone have a chipamp design that could easily drive a stereo pair of Magnepan 1.6QRs? They are a challenging 4ohm load and require at least 120W / Channel into 8 with something that can go down to 4ohm.
I was thinking that a pair LM4780's running in bridged-parallel mode per channel should do the trick. That and a boatload of capacitance plus a 300VA/25 volt dual tap Hammond transformer per channel so you've got dual-mono operation.
Anyone with experience driving eletrostats or planar ribbons with Gainclones? Any special problems other than the low impedance and high power requirements?
thanks guys...
(BTW: I've been reading the Zero Distortion power supply design article and its very informative http://www.zero-distortion.com/techn...powersi_05.htm)
Don't believe everything you think!
Old 7th February 2007, 07:10 PM   #2
AndrewT is online now AndrewT  Scotland
a second-hand Krell seems more suitable than a chipamp or group of chipamps.
Or join the KSA100 Klone threaders and build your own Magnepan driver.
regards Andrew T.
Old 7th February 2007, 10:54 PM   #3
Default ESL's and chips
I had the chance to preview one of my BPA300+ chip amp designs on a set of Martin Logan Summits, the amp preformed perfectly, but my amp cost well over 1K dollars to assemble so I would have to agree with Andrew T look at the krell clone threads would probably be cheaper in the end and work as well or better
Old 16th February 2007, 12:50 AM   #4
billbo is offline billbo  Australia
Default stk amp
If you are on a budget and want resonable performance, try a couple of stk4048xi's. They are cheap, work great and easy to build. I have posted pics in the amp gallery on page 28
Cheers
Billy
Chip Amp Power Relay logonwheeler Chip Amps 10 15th September 2006 08:36 AM
Looking for a Chip to get much power with 12-14V Bassterror Chip Amps 0 29th July 2006 12:48 PM
Paradigm power sub chip amp steven344 Chip Amps 2 24th November 2005 03:49 PM
power/heat from chip amp xplod1236 Chip Amps 11 21st July 2004 02:58 AM
low power digital chip amp Raj1 Chip Amps 4 24th September 2003 11:43 AM
Page generated in 0.09617 seconds (58.28% PHP - 41.72% MySQL) with 10 queries
