| Chip Amps Amplifiers based on integrated circuits |
ok so im building a 3 channel Lm3886 amp. R,L and sub.
I want to use it to monitor my mixes with a sub and just to basically a/b my mixes between my JBL LSR 6328p near fields, some KRK-5's and the LM3886 (pushing JBL's and a Pioneer sub). My question is (using Chipamp.com pcb's) if i run xlr to the Lm3886 is this still actually considered balanced? pin 1 goes to chassis ground, pin2 is hot , and pin 3 eventually get grounded too right? Basically im confused, and i just confused myself even more. Mainly cause i just read on the FirstWatt website, Mr Pass said that most of his customers dont need a balanced cable, but i was always under the impression that a balanced cable is better, not just for long mic runs but for signal quality. so i guess my question is will it make a difference if i run xlr or just 1/4 inch to the LM3886 coming from a balanced source?
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#2 | ||
diyAudio Moderator Emeritus
Brian |
#3 |
And again
![]() Running balanced makes you more independent of the electrical safety earth wiring in your studio facility, as it connects chassis ground of mixer console and speakers independent of signal levels. Unbalanced wiring uses the cable shield as signal ground, which imposes the signal reference to the chassis ground. If two chassi have different ground potential throughout your room, this will introduce an AC signal corresponding to that ground potential difference into your audio signal: hum. Two solutions: a transformer-based input converter (called DI-box) that adapts balanced line connections to unbalanced amp inputs - or a balanced line receiver module inside your amplifier enclosure. The latter one is cooler and can be found even for chip amps. Look for Texas Instrument's INA134 if you're interrested. Hope... ![]() edit: Poster lgreen's website has moved, but his button works.
#4 |
ok why is it important to make a balanced to single ended receiver? either way i want to look more into this but what would it matter without the receiver? quality loss? obviously it wont be balanced but what would the receiver do different?
#5 |
Signal quality and noise immunity are the main reasons.
You can use the + and ground wires of a balanced signal to feed an unbalanced input, but it is not designed for that so don't expect as much out of it. If you ground the - signal of a balanced signal then you are really just shorting the output of the balanced source to ground. Some sources might not like this.
Brian |
#6 |
The whole connection would then work unbalanced, which is perfectly okay if sound quality isn't harmed. Pin 1 (always) is ground, pin 2 then becomes the only signal connection and pin 3 goes to ground in this case, too. In order to play it safe, use resistors in the order of a couple Ohm to connect pins 2 and 3.
But you can't go back, then. Doing it with a balanced line receiver lets you keep all the options... ![]() edit: Brian, a day off?
#7 |
sek, our brains appear to be synchronized today
![]() I'm actually "working" at my desk today
Brian |
#8 |
Very special!
I bet You're writing on something I'm writing on...
#9 |
ok brian, Sek thanks for your input. appreciate it.
| Balanced zen line stage | hcbonfim | Pass Labs | 17 | 4th June 2007 09:17 PM |
| Balanced Line to Mic Pad DIY?? | Zero Cool | Instruments and Amps | 2 | 23rd February 2006 04:38 PM |
| Balanced Zen v5 + balanced Zen line stage | Adrie | Pass Labs | 0 | 30th May 2004 05:27 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Balanced line | jleaman | Pass Labs | 130 | 26th October 2002 08:57 PM |
| Page generated in 0.10862 seconds (74.63% PHP - 25.37% MySQL) with 10 queries |
