| Chip Amps Amplifiers based on integrated circuits |
Hi all,
Yesterday I managed to score a Mission 70ASA 100w active subwoofer for a lowly $30, only the amp seems to be completely busted, and blows fuses one after the other. I pulled off the panel, and it seems to be a "s53ami" module digital amp, which have a reputation for crapping out. So I'm thinking of replacing the amp with a lm3886 following an active low pass filter. The transformer that came with it has 33V secondaries but seems to be sort of small-ish for an amp that is supposed to be 100w. Do you think that I should ditch it and find a new one or will it work out okay? Any suggestions for how I should go about this? Are their better solutions then the lm3886? |
#2 |
diyAudio Moderator Emeritus
You may want to have a look at some class d modules.
Brian |
#3 |
Wouldn't 33VAC secondaries give something like +/- 46VDC when rectified? And isn't that 4v over the max of the 3886/4780?
#4 |
Hi
if your woofer has min 8Ohm, you could parallel 2 TDA7293. |
#5 |
I'd recommend bridge-tied loading or parallelling of LM3886s according to National's AN-1192.
Or buy a UCD module. BPAs are cheaper, though.
#6 |
Did it Himself
IMO for just 100 watts class-ab is fine and will be cheaper and DIY. Could you fit something like a P3a in there?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
To support richie00boy's comments - I have a paralleled 4780 feeding a cheap 12" 4ohm driver - and at 75% of the output volume from the pre-amp it sits about right with the rest of the speakers in the room. The sub isn't in a box yet - nor does it have the Linkwitz transform I intend to use, so that could all change.
The LM4780 is running +/- 24.5VDC supply which the Overture Design Guide Spreadsheet tells me should give about 105W output power. With +/- 34VDC the output power (for a parallel setup) raises to 205W - and the size of the heatsink starts to get big too. |
#8 | |
Brian |
#9 |
I measured around 80wrms in lab with my lm4780, with a 2x25vac transformer putting out +/- ~34vdc, with a 4 ohm resistive load box.
If you need much higher power for a sub, I would try again to search for a cheap plate amp. -- Brian |
#10 |
Thanks for the responses guys!
I will look into some class-d solutions.. but I don't think it needs to be too powerful. It is 8-inch driver and I have a small appartment. Furthermore the box is about about a 1.5x1.5x1.5 cube -- not too big. Ideally I would use the existing transformer because it is allready mounted to the inside quite nicely.. but as raromachine pointed out, +/- 46VDC will be a bit much for the 3886/4780's. Also it is not that big/heavy so I worry that the VA rating is not very high. I guess I will have to go transformer shopping. I figure something in the 70-100 W area would work quite nicely. I don't really have the resources to make PCB's so that's why I was thinking part to part gainclone, but if there are kits available that would be cool too. What do you suggest?? |
| Silicon chip subwoofer controller | pinco | Solid State | 0 | 31st December 2007 07:40 AM |
| chip for a subwoofer amp (~20w)? | facundonu | Chip Amps | 15 | 14th November 2006 04:45 PM |
| would a chip amp work on a mini subwoofer | PimpMyRide | Chip Amps | 4 | 15th November 2005 11:00 AM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| Good but simple subwoofer chip amp. circuit suggestion | Alvin | Chip Amps | 2 | 17th January 2004 01:04 PM |
| Page generated in 0.20699 seconds (44.91% PHP - 55.09% MySQL) with 10 queries |
