Old 23rd September 2004, 02:20 PM   #801
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Re: ECC86; running it at a +/- 35 rail is already rather "high voltage" for this valve. It was designed to run from low voltage car battery supplies.
Did I wrote +/-35V for ECC86? Of course to high, max +/- 15V!
Ahh, I see: I asked about a E88CC and +/- 35V.
Sorry
Franz
Old 23rd September 2004, 02:31 PM   #802
diyAudio Senior Member
fdegrove's Avatar
I just thought I'd mention it before someone just drops in a ECC86 en lieu of the ECC88 and say they don't like what they're hearing based on those findings.
Personally I don't really like low voltage valves but that's another story....
Here's some data on the ECC86/6GM8:
ECC86
Frank
Old 23rd September 2004, 02:37 PM   #803
Banned
Originally posted by Franz G
Wrong, dear Carlos!
The difference between input and output must be within 37V.The chip itself is floating and independent of the voltage.
You could even use LM1083.
Franz
Yes, you are right.
This sentence on the datasheet confused me:
"The LM117 series of adjustable 3-terminal positive voltage
regulators is capable of supplying in excess of 1.5A over a
1.2V to 37V output range."
Old 23rd September 2004, 06:13 PM   #804
Franz G's Avatar
Carlos: I always feel the same about datasheets: I read them 100 times (at toilet, in the bed, watching tv and so on).
And I think: Yes, you got it, Franz.
But then, I try a new circuit. And I get a problem. Then I read the datasheet again:
The first sentence gives the solution
This is the hard way, to learn.
What is more important? The goal or the way? (Konfuzius, isn't it?).
Franz
Old 23rd September 2004, 06:17 PM   #805
frugal-phile(tm)
planet10's Avatar
I read them 100 times (at toilet ...
Around here we call that the library...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd September 2004, 06:26 PM   #806
Franz G's Avatar
Actually, I am not sure, if the version with the low voltage ECC86 or the version with higher voltage E88CC is sounding better.
I just feel, it is the E88CC, I am not total convinced about the ECC86 solution. Some dynamics missing?
Soon, I will have the chance, to compare both versions: I have an order to build and sell one VBIGC, so I produced two boards.
The number two of this boards is now playing with the ECC86. The second board, number one (for the customer) will include an E88CC with adequate voltage.
Then, I will have the chance to compare both amps.
I will inform here.
Franz
Old 23rd September 2004, 06:47 PM   #807
Banned
Carlos: I always feel the same about datasheets: I read them 100 times (at toilet...)
You guys should try to read the DIR1703 datasheet.
Hard to follow, even in the library.
The guy that wrote it didn't even know how to talk.
It must have been the same engineer that developed the chip, as it had a bug and TI removed them, not available anymore.
Old 23rd September 2004, 06:51 PM   #808
Franz G's Avatar
... good, we have a forum.
We will squetch it out. The ultimate solution!
Franz
Old 23rd September 2004, 07:04 PM   #809
Franz, f... off 86 - it is much more nonlinear than 88, so you get only bigger distortion .
Old 23rd September 2004, 07:11 PM   #810
Franz G's Avatar
Franz, **** off 86 - it is much more nonlinear than 88, so you get only bigger distortion
Sorry, I removed the censored part of your text
It must be this way: actually (with ECC86), La Traviata, does sound like through fog...
Franz
Edit: I just removed the ECC86 and put in the E88CC with only +/-11V.
Result: much more dynamics, at least. The fog is gone. And it does work!?! Amazing, isn't it? But I will of course go back to a adequate Ub (+/-50V to +/- 60V) for the E88CC.
Page generated in 0.10145 seconds (85.16% PHP - 14.84% MySQL) with 11 queries
