| Chip Amps Amplifiers based on integrated circuits |
#701 |
OK guys, both me and Nuuk overlooked the LPF’s resistor but we’ve been through that long time ago, the accent was now on the way to calculate the effective value of the resistances used in the feedback, and to clarify possible puzzle about this. I hope the link I have provided may give the answer the people may need.
#702 | |
Banned
Taste...
#703 |
This may help calculating T-Network values versus gain:
Download CircuitMaker Student Version 6: http://www.altium.com/circuitmaker/d...ds/student.htm Install it. Now download this tiny zip file: http://members.ozemail.com.au/~joeras/diy/T-Network.zip Unpack and in CircuitMaker open this file. You will now see a basic diagram of opamp using T-Network inverted feedback. Double click on any resistor allows the values to be changed. Keep in mind 100k = 100k but 100 = 100 Ohm. Now choose 'Run' from the Simulation drop-down menu or use F10. The AC Voltmeter will then show the AC voltage out. Since it is set up with 1V RMS (+/- 1.414V) - the RMS value equals the gain, hence 46.23V means gain = 46.23 See how you go, let me know of any success. Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#704 |
G'day Joe,
I downloaded the zip file and unpacked it but when I try and open a file in CircuitMaker I only have the option of opening ckt or binary files. The file in the zip is an XLS!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#705 | |
The file in T-Network.zip is called T-Network.ckt and was created by CM Student V6. What is the XLS full name? If it ends up T-Network.xls - then I am most definitely confused. ![]() If so, edit to read T-Network.ckt . Also it should 4399 bytes. Joe R.
#706 |
Did anyone notice/observe/think how T-network in the feedback influences the relation between the amplitude and phase? I ran some sims with the opamp model that should match relatively well to those commonly used in the GCs (its open loop measurement shows about 3MHz bandwidth and somewhat better phase margin than LM3875’s but with generally similar shape), anyway I think it is good enough to show differences between particular configurations.
Here is its response when used in the inverted configuration and with commonly used IGC feedback of 220k/10k. ![]() Keeping the same gain and going down with the feedback values to match the future T-network’s 10k of summed resistance between the output and the inverted input, i.e. with feedback 10k/454R, the response shows better phase, probably because the pole formed by the input capacitance and feedback resistance is shifted higher. ![]() Now, the same gain and T-network in the feedback (5k/118.8R/5k). Obviously, response disappears earlier, leaving the phase at new unity gain point still better. ![]() Pedja |
#707 |
Banned
Will you guys still call this a Gainclone?
#708 | |
So the phase is straighter because, with the lower Z we're more able to drive the input capacitance. That sounds rather rational. So I got the idea, this is an opamp capable of driving Lo Z speaker loads, hence in a T network can be made really low as it will have no difficulty driving that. So how about making the T 2 x 1K (make these 1 Watt) and One Ohm. With my 4k7 + 18K input Z (22K7 total), this gives a gain of 45. This not gets maximum drive but should also give low DC offset. Joe R.
#709 | |
#710 | |
| Page generated in 0.11450 seconds (77.13% PHP - 22.87% MySQL) with 11 queries |
