Old 31st August 2003, 05:11 PM   #431
Nielsio is offline Nielsio  Netherlands
Nielsio's Avatar
Most of them have been sold in Australia and New Zealand. None in the U.S. as they have 115V AC (late this year or early next year some will be made). There are two in Europe at the moment with a third on the way.
We are arranging for an on-line review out of Europe soon. When it eventuates, will make an annoucement on this forum.
If you are interested in one, I have current stock and can send one immediately. For EUR 1100.00 which includes Economy Air Freight (it's quick this time of year). It's sent in a plain box with private names only. On the other occasions there have been no additional charges from customs. So the price I quoted should be all that is needed to pay.
Ok. Thanks very much for the information. I was asking this because I might be interested in buying one at a later stadium.
I will be at the European Triode Festival in the south of Germany, near Lake Constance (Bodensee), the first weekend of December. I believe the place is called Langenargen.
Yes, I will have a JLTi amp there, ready to be compared with the best?
There is going to be some interesting stuff there. I hope they will make Saturday Dec 6th will be 'open day' where non-paying participaters will be able to attend. We, Allen Wright and myself, will be there from Thursday to Sunday.
Good to hear! Let's hope I can make it.
E-MU 0404 . Behringer DEQ2496 . TDA1543 NOS . JLTi tube buffered LM3875 . Supravox 215 Signature Bicone 125L vented
Old 15th September 2003, 07:26 PM   #432
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Hi Joe & others,
Firstly, I've built two Gainclones. Neither are inverted and I don't own either of them! One belongs to my Sister and the other is my Brother's. Ever since I heard the first one, I fell in love with them. They may not be the best amp I've ever heard / built - but certainly have the highest QPP rating (Quality Per Pound ). I'm hoping that your superb work will change that and make them the best I've heard...
Here are my questions...I like to play my music loud (when my fiance goes out of course! ) I don't feel that the gainclones go loud enough for my liking. I was thinking about bridging two LM3875TF s. I have 10 of them and would like to use them rather than buying 3886s. I see that in the schematic you have one tube shared between both channels. I am wanting to build monoblocks. Can I just use half the tube successfully or is there a way to use both sides? Maybe use the buffer after the invertor and then I can use both sides of the tube for each chip.
Please bear with these seemingly stupid questions - but I've never had anything to do with tubes or bridged amps.
Thanks!!!
Gaz
Old 15th September 2003, 08:01 PM   #433
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Hey Rarkov:
I was thinking along similar lines, and am even more ignorant than you. I also want monoblocks and I'm pretty sure you can just use half the tube. BUT, why not use both sides to make a balanced amp or parallel or something. I'm getting the idea around here that using two chips in a balanced config doesn't automatically get you more power, BUT I think it would probably dispurse the heat better and allow higher voltage? Parallel is that different? I think so and prob does put out more power.
Boy , now they're clutching their head in amazement at my pathetic puddle of knowlege!!!
My main point is that you meant to say use one side of the tube for each chip(2 total) in the monoblock I think.
Old 15th September 2003, 08:50 PM   #434
Rarkov's Avatar
Hi Variac. I hadn't read back my post so I didn't realise it was unclear. Yes, I want to use one tube per monoblock, and one half per chip in bridged mode.
Gaz
Old 15th September 2003, 08:52 PM   #435
frugal-phile(tm)
planet10's Avatar
Sure. If you wire the 2nd monoblock so that it uses the other half of the tube then switching tubes from one monobloc to the other will be like putting fresh tubes in.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th September 2003, 09:56 PM   #436
Rarkov's Avatar
Hi Dave,
I had to read that a few times for it to sink in! I thought you were making some kind of joke at first! Just me being stupid!
I didn't know if it was possible to use just half of the tube. It would save on money I suppose to wire it as you suggested. Another stupid question - I have never seen let alone heard tubes before...Does using half of a tube as opposed to both halves effect the aesthetics?
Gaz
Old 15th September 2003, 10:15 PM   #437
diyAudio Senior Member
fdegrove's Avatar
Nah...
What you can do too with a CF as this is wire both halves in parallel for even better current drive and lower Zo.
This requires well match triode halves as current hogging will occur otherwise but that's another chapter.
Personally I'd stick to Dave's idea though, it's elegant enough and easy to swap around the tubes every year or so.
Pinout of the 6DJ8 and kin:
Frank
Old 16th September 2003, 02:52 AM   #438
Send a message via Yahoo to mikelm
Default valve phase splitter
For simplest balanced operation you could try looking around for a valve phase splitter cct.
Old 16th September 2003, 09:49 AM   #439
fdegrove's Avatar
Instead of going balanced PP why not put both chips in PSE?
Either leave one half of the 6DJ8 unused or put both triode sections in // as well for greater current drive.
Frank
Old 16th September 2003, 12:06 PM   #440
Rarkov's Avatar
Hiya...
I think Dave's idea has the greatest advantage. I'll just run the rails as high as I can to get the volume (I've not used them at 35V before....maybe that will be enough).
Thanks,
Gaz
Copyright ©1999-2013 diyAudio
