| Chip Amps Amplifiers based on integrated circuits |
#21 | |
PS If I weren't a DIYer, I would most likely buy your amp; good price for a great product. |
#22 | |
so far are most promising. Thank you for your kind remarks. It's kinda funny that the JLTi ends up as a subject in DIY discussion forum when it isn't a DIY product. It's only that it uses an element familiar to some DIY-selfers. But so does other commercial products as well. After all, audio is made up of many diverse bits, DIY or otherwise. It's all about how you combine them. It's cooking! :-) But having said that, I would like pass on some of my ideas (discoveries?) and let's see how it is received. I want this contribution to be very well thought out and presented. It may take about two weeks as I may want to include actual measurements. This will be a comprehensive presentation. At least I have accomplished something others have not done yet, combining tubes and the 'gainclone' IC. The idea has been spoken about it, but has anyone actually done it? Personally I love the results - it works beautifully! Thorsten sent me an email saying that he had suggested it in a November post (another forum) and gave me the link. But I had already started this well before then. Here is the URL he sent me: Hybrid "SE Tube Amp Sound Style" Chip Amp idea I didn't follow his suggestion of making the 'gainclone' behave more like an SET or adding 2nd harmonic warmth. I trusted my instincts and went for the cleanest possible signal path, the Tube Buffer I use is very low distortion and very wide bandwidth. Actually hugely wider than the IC, which led to a problem I had to solve. Another absolutely important aspect of the Tube Buffer is the power supply solution I came up with. I also the same idea for the optional Phono Stage, so have a look, it the third illustration down on the page: http://members.ozemail.com.au/~joeras/jlti_phono.htm The main difference here is that the +15V/-15V is +55V/-55V for the Tube stage. Regards Joe
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#23 |
Hi Joe, just wondering if you've had the time to get any work done on the schematic of your non-tube IC amp.
Regards, Eric |
#24 | |
Please be patient. You will be happy to know that I have already started preparing diagrams and circuits. There will two designs presented, one can be easily adapted to current GCs, it requires a number of values altered and a few additional components. Also a change to either 10K Log Pot OR 25 Log Pot. The original 50K Lin Pot will be discarded. The SECOND design will be far more ambitious. This will be a simplified version of the JLTi. This is for the SERIOUS constructor! YES, A DIY HYBRID TUBE GC. But the power supply solutions to the tube front- end will need to be filled in by the DIY-selfer. The +35V & -35V supply can be done using a small 25V-0-25V 30VA tx, toroidals should be available, and same 1000uF/35V caps as using by the GC chip. This will give us a very well filtered but unregu- lated supply. If the constructor wants to regulate this... go ahead with whatever solution you can or want to come up with. Also a 6.3V 330mA supply will be required for the filament. The choice of tube (suggestion) will be the same as the JLTi, the Sovtek 'Relector' 6922, as this tube will work at the low (no high-tension here) voltages used. Hope that has got your appetite up. I'm looking at two weeks, hang in there. Regards Joe
#25 |
Hi Guys
Check this out: ![]() Yes, actual component values will be supplied. This is the simplified JLTi for the DIY mafioso... Promise! Joe
#26 |
#One mafioso getting excited
#27 | |
Joe, take all the time you want. I realize that you're busy at your job, and DIY'ers make little or no money for you .Thank you for the update. |
#28 |
Seems I have missed this thread somehow. Yeah Joe, take your time and keep us posted.
#29 |
Was just testing if my signature works, but I can't delete the message.
Well, guess I have to say something smart now. Ok, I've got one: Why is it that the exact grounding is never included in the schematics? Especially when it seems to matter so much. Not everyone here is a Kuei, a Peter or a Joe.
E-MU 0404 . Behringer DEQ2496 . TDA1543 NOS . JLTi tube buffered LM3875 . Supravox 215 Signature Bicone 125L vented |
#30 |
Originally posted by Nielsio
"Why is it that the exact grounding is never included in the schematics? Especially when it seems to matter so much." ============================================= ...Because, then everyone would be able to build a nice sounding equipment Regards George |
| Page generated in 0.14195 seconds (79.52% PHP - 20.48% MySQL) with 11 queries |
