| Chip Amps Amplifiers based on integrated circuits |
i need some help. i did as stated in ILP pdf and immediatly popped a fuse. as you can see on the left there is an orange, brown, black and light pink (which im guessing is white). right next to those are another bunch of the same color code but there is a little yellow w/ green stripe wire with them, which the pdf states nothing of. i did the first config. and blew a line fuse once i hit the switch. what could i be doing wrong? there is so many wires, i think it was a custom torodial cuz the pdf doesnt mention most of them.
anyone have an idea? i'd much appreciate it.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#2 |
hi,
your schematic does not jibe with the actual transformer as per your picture. if i were you i'd proceed as follows: 1. i will connect a low voltage, say 6volts ac to any of the secondary windings. 2. measure voltages on the other windings. then i will connect those primary wires so that voltage from end to end add up. looks to me you have dual primary windings with taps, (just a guess), the green yellow wire could be the electrostatic shield.
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#3 |
build yourself a mains bulb tester. Use it every time you want to switch on a new build project or maintenance/rebuild project for the first time. The in series bulb prevents large currents flowing from the mains. If you have wired the primaries of the transformer incorrectly, the bulb will glow bright absorbing the mains voltage and passing just a few volts to the bad appliance.
regards Andrew T. |
#4 |
ok guys thanks i'll give it a shot. i emailed the company with a pic and p/num. a few days ago but they never replied so screw them. i'll be back if i have more trouble. but 1st i will make what andrew t just mentioned. thanks again
#5 |
Andrew i just did a little search on mains bulb tester and came up empty. do you know of a site? i'll keep searching but if you know where i can go that would be cool
#6 |
I just entered "bulb" in search for items and "andrewt" in search for user name and came up with 59 references on this Forum. Others have written about it and drawn it. I found out about in this Forum and use it "EVERY" time.
regards Andrew T. |
#7 |
sweet thanks
| Power Transformer 110/230V Windings Question | LinuksGuru | Tubes / Valves | 4 | 13th July 2009 10:26 PM |
| Transformer from Sony A/V Receiver - what's up with these windings? | Stephen Morgan | Solid State | 15 | 7th February 2007 05:11 AM |
| transformer primary windings Q | AndrewT | Power Supplies | 6 | 28th October 2006 11:51 AM |
| Unused HV windings on power transformer | Bill*B | Tubes / Valves | 2 | 5th March 2005 09:42 PM |
| Transformer windings identifications - how to get it? | Alfetta87 | Solid State | 7 | 21st February 2005 04:01 PM |
| Page generated in 0.09553 seconds (69.80% PHP - 30.20% MySQL) with 10 queries |
