a pop when i power down
Old 31st January 2007, 12:49 AM   #1
impsick is offline impsick  United States
impsick's Avatar
Default a pop when i power down
ok so built the LM3875 with PDaniels pcbs. it s sounds good buy the way. but when i flip the power switch to off the speakers do a little pop. how do get rid of that? i dont know where to even start trouble shooting that.
the rectifier board i added the snubber components if that helps. the big caps are 50v 4700uf.
id appreciate any help. thanks
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 31st January 2007, 05:28 AM   #2
rehanabid is offline rehanabid  Pakistan
Though I have never used the chip but its datasheet does not show that it has a popup noise control circuit while powering on/off.
I hope P.D and other experts here could enlighten more however, as far as I am concerned there is nothing to troubleshoot about as in the abscence a popup noise control its natural for the amp to behave like that.
You could also add bleeder resistor on powersupplies.
Old 31st January 2007, 11:01 AM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
On the first page of the datasheet it says: "Supply under-voltage protection, not allowing internal biasing to occur when |V+| + |V-| = 12V, thus eliminating turn-on and turn-off transients"
If you shut down the supply while listening to music you will hear the chip shut down when the supply caps discharge below around 12V. You will hear a little click but it shouldn't be harmful to speakers. Do you have an active preamp that shuts down at the same time?
Brian
Old 31st January 2007, 11:10 AM   #4
impsick's Avatar
no just an alps blue. but i've been turning the volume down and then i would hit the power switch
Old 31st January 2007, 11:13 AM   #5
Burnedfingers is offline Burnedfingers  United States
There is a chip amp mute circuit thread. I have a circuit to eliminate the power on power off noise.
Unfortunately it won't apply to the chip that you are using. It will work with the LM3886 however.
Old 31st January 2007, 11:14 AM   #6
impsick's Avatar
wheres that? whats that? i wanna see
Old 31st January 2007, 11:26 AM   #7
BWRX's Avatar
It won't help because the LM3875 doesn't have a mute pin like the LM3886.
How loud is the pop you're hearing? When I power down my LM3875 I just hear a click when the rail voltage drops below ~10V. However, I also have opamps in front of the LM3875 that I turn off after the chip's supply discharges.
Brian
Old 31st January 2007, 11:44 AM   #8
impsick's Avatar
its not really that loud. its kind of a click or pop. but where is some info on your curcuit i got some 3886's im gonna put together here.
would changing the value of resistr between the big 4700uf caps do anything? they are .2ohm right now.
Old 31st January 2007, 11:52 AM   #9
If you read my edited post you will see that I already made a mention to this.
Old 1st February 2007, 01:05 AM   #10
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
It's kind of strange to me there is a 'pop' when switch off a GC.My DDGC
doesn't exhibit such problem with a pair of 2200uF caps and a LM3875 and a 200VA EI transformer.
a pop when i power downHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
