The sound of TDA7294 - Page 2 - diyAudio
Old 12th January 2003, 05:44 AM   #11
sangram is offline sangram  India
Well, mistake. Looking at the graphs again, 170 W into 16 ohms is at 10% THD. Not useful. The actual rating should be close to 120 W. Useful...
Old 12th January 2003, 11:45 AM   #12
Jaac is offline Jaac  Netherlands
Jaac's Avatar
hi
i've build also a tda based amp. the sound is good not very good but good if you have a good power supply i used a 300VA 30-0-30 V amplimo with a total of 40000 uF buffering here are some pics;
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 12th January 2003, 05:58 PM   #13
vuki is offline vuki  Croatia
vuki's Avatar
What coniguration do you use? Any advantage to inverting config for TDa7294?
I'm using noninv. configuration and I haven't try inverting because of internal muting switch dealing with inputs (according to app. note's diagram). As the IC is quite sensitive and usually doesn't respond well to applications different than suggested in ap. note I didn't want to risk any more...
I already burned handfull of IC's trying to make 3x parallel TDA7293 configuration work. Later, on some german forums, I found that others who tried it had similar results .
There are some more threads about it (search for rljones or vuki).
So: why don't you try it and tell us if it works?
Old 13th January 2003, 12:34 AM   #14
alvaius is offline alvaius  Canada
I will try. I have quite a few of them, so if I kill them it is not a big deal.
Alvaius
Old 16th January 2003, 11:02 AM   #15
Bricolo is offline Bricolo  France
Bricolo's Avatar
thos who tested a 7294 and liked it: what shematic did you use? the one in the datasheet (non inverting)
is inverting better sounding?
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
Copyright 1999-2017 diyAudio
