Old 26th January 2007, 10:48 AM   #1
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh Send a message via Skype™ to kuldeepsingh
Wink Single sided 4780 PCB ready
Yahoo!!, at last my first 4780 PCB is ready. Just have a look at this beautiful picture. Planning to made on Order within India boundaries.
Old 26th January 2007, 10:51 AM   #2
Lightbulb PCB LAyout
Here is the actual size PCB Layout (component side - Print exactly for Laser Print transfer PCB making). Circuit is LM4780 reference layout as in the datasheet.
Old 26th January 2007, 11:00 AM   #3
impsick is offline impsick  United States
impsick's Avatar
nice.
i need to get a laser printer.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 26th January 2007, 11:09 AM   #4
Arrow The drill i used for drilling holes
I used a simple cassette drive motor and fitted a hand filed shaft in form of drill. little hit and trial is required to get fine drilling thickness.
Old 28th January 2007, 08:50 AM   #5
Lightbulb More compact layout.
This is first revision of the PCb and successfully able to further compact the PCB, only 42 * 55 mm for one LM4780
cyan lines repesents capacitors and magenta lines represents resistor
Old 28th January 2007, 08:53 AM   #6
Arrow component layout
cyan lines - capacitors
magenta lines - resistor
Old 28th January 2007, 03:48 PM   #7
notes:
1.) jumpers?
2.) many small PCB designs place the large caps directly in front of the mounting holes. you may need to solder the caps AFTER the pcb is mounted.
if only it could be used for good, not evil...
Old 29th January 2007, 05:01 PM   #8
Originally posted by theChris
notes:
1.) jumpers?
Jumper setup for the 4780 PCB. Circuit is as per LM4780 reference PCB schematic and also suits for special audio application amplifier (arrangement for Cf and Rf2 has to made on solder side of PCb if required).
There are no mounting holes on the PCB, mainly for compactness, the IC after mounting on heatsink will supports the pcb. But if required a mounting hole can be made on the left to muting resistor.
Old 1st April 2007, 07:56 AM   #9
Default MAjor layour change - reduced jumpers
after a major design change, i have able to reduced the jumpers to 3 nos only. No jumpers in signal line in new layout, further the whole circuit is very symmetrical with star ground. This time i made in 2 sizes, standard version PCB to accomodate 4700 muF caps and a compact PCb for 1000 muF caps.
More pics available at http://www.geocities.com/cool_mechi/lm4780.htm
4780 single sided pcb redesigned gmphadte Chip Amps 24 25th June 2011 04:09 AM
4780 stereo, parallel, bridged, single sided gmphadte Chip Amps 12 12th March 2007 11:42 AM
Single sided GC DragonMaster Chip Amps 16 9th April 2006 08:50 PM
4780 3in1 single sided gmphadte Chip Amps 5 9th March 2006 02:02 AM
Page generated in 0.74015 seconds (11.65% PHP - 88.35% MySQL) with 11 queries
