| Chip Amps Amplifiers based on integrated circuits |
I built my first Gainclone from Brians basic LM3875 kit and I'm very pleased with the results such that I now want to tinker more.
Currently I have the two amps and the transformer in one single very cheap metal case. I'm interested in qualitative opinions on the improvement in quality by respectively, 1. Putting the transformer into a separate case. 2. Putting the single transformer and two amp boards into three separate cases. 3. Buying another transformer and going the monoblock route. Regards Alan |
#2 |
Option 3 is the only one likely to result in an audible improvement IMHO!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
I have had little lcuk bringing my EI core too close to the amp... toroids will work better.... but I think if you want to go full tilt, I would stick with 3 boxes keep one for the 2 power supplies... in one, and the monoblocks in the other two.
#4 | |
Old square EI type transformers have somewhat higher level of electromagnetic radiation field around them Toroid also radiate, but not as much. 1. No transformer should be put too close to Input of amplifier or near unshielded input / supply wiringd 2. Especially old EI types, I would put at least 20-30 cm away in a box: put input circuit in one end .. and transformer in other end 3. Of course this is more important, The Bigger transformer is. Small trafo - little radiation Big Trafo - big radiaton .. evenso from Toroid! Main 2 differences between EI-Type and Toroids: EI-types: more electromagnetic radiation Toroids: more peak inrush currents at Switch On and so initial Capacitor Loading currents .. may be a few more differences, but those are what I know are the main things to consider Regards, lineup
lineup |
#5 |
I'm using an RFI and EMI shielded Plitron 300VA toroid for the given reasons. Also am shielding the trafo real estate of the enclosure with TI Shield and enclosing the mains and supply wires in copper mesh tubing. While paying attention to layout as is possible in a small enclosure, this combination works like a charm.
The Plitron is special order; don't know where else you can get the RFI and EMI options. The TI Shield and copper braid tubing can be purchased from Michael Percy. George |
#6 |
Toroids biggest most magnetic field in the z axis or straight perpendicular from the center of the doughnut. This means that it's important to route wires around the tranny and not over them. You can prolly place a toroidal tranny very near an amp board side by side with little adverse effect. Matter of fact, I would think that long leads of any kind inside a chassis prolly cause more noise and grounding problems than sweating out where yoou place the tranny.
Now as far as RFI...a strict interpretation of that would mean radio frequency and that has little to do with a tranny operating at 50Hz/60Hz. If you truly worry about RFI, then consider the leads in your chassis (and your power cord externally) becoming antennae and picking up stray RFI from the air. Twisting the wires can help to reject RFI. Adding a Corcom power jack or a ferrite may also help for the power cord. |
#7 |
A metal belly band is recommended to cut down on EMI from toroidal trannies. This could be a simple piece of copper tape or something more elaborate made or beyllium or some other boutique metal. Overkill?
| PMD-100 options? | Skorpio | Digital Source | 12 | 15th May 2009 08:00 AM |
| CCS Kit options | eeyore | Tubes / Valves | 19 | 18th April 2009 03:29 PM |
| 230 V. > 110 V. -- options? | on the move | Everything Else | 2 | 25th July 2005 04:01 PM |
| Any Bi-Amp options? | chris ma | Everything Else | 3 | 10th May 2002 10:02 PM |
| Page generated in 0.13262 seconds (59.26% PHP - 40.74% MySQL) with 10 queries |
